Question about Konica Minolta PagePro 1350W Laser Printer
Pagepro 1350 will not feed paper
The pagepro wont feed the paper even though the tray is filled up. After every try I get a paperjam mesaage. However there is no paperjam and after I follow the on screen directions (open front cover remove powder tray) then replace them the machine goes thru the motions once again with the same results
  • Anonymous Nov 16, 2008
    I have had the same problem for a long time. I switched from regular 20lb to 24lb paper, which has worked for the last year or so. But now the printer won't pick up any paper except when I try to force each page in by hand. The frustration is no longer worth the effort. I think I am going to buy a new printer.
  • Anonymous Jan 10, 2009
    I just don't understand it! I have had the same problem since I got it. When it is new, the problem is not severe. But, now, I need to sit beside the printer to help the printer.
  • 165 Answers
I have the same printer and had the same problem.
Cleaned takeup roller wit isopropyl and it has worked now for 18 months. If you dont use it often, remove top sheet from stack and blow the dust off it before printing.
Posted on Jan 27, 2009
I had the same problem - fails to feed paper.
What I did is, I took a 6" x 3" x 1/4" piece of plastic (Plywood will work too) and placed it under the paper stack close to the roller. This was like a bump under the stack of paper before the paper is fed into the roller. Believe it or not, I never had the problem again.
Soma S
Posted on Dec 15, 2011
  • 48 Answers
There is a roller in the paper feed tray that picks up the top sheet of paper. A temp fix is to clean this roller with isopropyl alcohol. Paper dust, etc.makes the surface of the "pick roller" too slick to grab the top sheet. I clean mine about twice a year. Cheap paper is dustier and might require you to get it cleaned more often. This fix is temp but requires NO disassembly, only cotton swabs, 91% Isopropyl (drugstore) and a small flashlight (so you can see what you are doing). What I want is a service kit so I can replace the roller and a few associated parts.
Posted on Jan 11, 2009
1350 toshiba copier copy gets stuck
You need to clean the feed rollers for all your trays and for your document feeder or adf. If that doesn't work then replace them. But before you do that try checking if there is any paper, ripped or otherwise blocking paper path and removie it. It may just be that simple.
TOSHIBA BD 1350 SUPPLIES
Sep 12, 2012 | Toshiba T1350 T-1350 Compatible Copier...
The amber light with the triangle next to it is flashing please help!!!
That is the ATTENTION state. Four things can cause it to flash.
1) empty paper tray
2) door open
3) paper jam
4) misfeed from tray.
Press the GO button(the diamond). If it still doesn't work, check for a paperjam.. Also try printing from the manual feed tray.
Aug 21, 2010 | HP LaserJet 1160 Printer
Says paper jam but NO paper is in the machine
One problem i found with those printers is that over time the casting around the paper tray is wearing off and printers starts to show paperjams when there is no paperjam.
One way to fix is try and positions the paper tray better or perhaps raising it a bit with piece of wood or paper.
Cast unfortenately is too expensive to replace so if this doesnt work and you are sure there is no paperjam and nothing obstructing the sensor then replace the printer.
Nov 02, 2009 | HP LaserJet 2200D Printer
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
Konica Minolta 1350 printer won't print with Vista
Also try turning spooler OFF/ON. Also, try turning 1350 OFF/ON. Those sometimes work. But 1350 had same problem with W98SE so must be a problem in 1350 software(?). I got so tired of this that I bought a Canon MFC which works perfectly. Still use 1350 to use up the toner.
Sep 15, 2009 | Konica Minolta PagePro 1350W Laser Printer
It acts like theres no paper in it.. wont feed even though theres paper in the rack.. not sure why
try to reinstall your driver.
try to do a paper feeding maintenance or roller plate cleaning.
Check the printer properties if you have these features on maintenance our printer.
Check if you insert the paper properly on the paper tray.
After you reinstall the driver, try to reboot your computer.
Aug 16, 2009 | Canon i860 InkJet Photo Printer
Mp780 - Paper attempts to feed and fails Message: Load paper
Your paper feed source is wrong .Go to the printers control panel and change the feed source.
If all you do is 8.5X11 you can go into the maintenance tab and choose it to automatically change paper trays by selectin auto continuous feed.Make sure paper is in both trays of the same type and size.You will hear the printer try and grab the paper three times then it will automatically switch to the next tray.
Jun 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
OKI B4100 paperjam warning
Acording your explained you need do
1) clean the input tray roller surface, to make sure it has enough grip force.
2) looking for a sensor around the roller rear, it could be cause the paper jam there, because if the sensor does not detect any input paper go throug there then should be stoped at roller rear.
3) if you find a optical sensor there, please use a slft cotton stick to clean its surface. (maybe open some cover needed)
hope you fix it , ask me any time please!
May 17, 2009 | OKI B4100 Laser Printer
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
Konica Minolta PagePro 1350W Laser Printer Logo
1,208 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
