Question about Sony SLV-D350P DVD Player/VCR
How to program vcr using L1L2
I cannot find anyone who knows how to program my new sony recorder using L1L2 how do you know
the station you are recording.
  • 166 Answers
I think that L1 and L2 are the extension inputs (scart/phono) from an external source therfor you will only be able to record whatever channel they are on. to make a timed recording you will have to input time date channel you will be unable to record via videoplus.
Posted on Dec 01, 2008
This is quite common of older players. Some only work with DVD+R discs and others with DVD-R discs.
Some player also does not read recordable discs (an early form to try prevent piracy)
Also make sure if recorded on your Recorder, that the disc is finalized before you try to play it on an older player. (See your menu / manual on the recorder for the procedure)
Feb 28, 2010 | Sony RDR-VX515 DVD Recorder/VCR
When i record spanish satalite station the recorded program goes black and white on a regular basis
Well, if the program is showing in color on the TV, then the TV is fine. If she's recording using a VCR, then I presume she doesn't have a cable box? If she doesn't have a cable box and has the cable from the wall going into the VCR and the VCR connected to the TV, then the problem is the VCR if the program appears in color when showing "live" on the TV but black and white when played back on the VCR. Does that make sense? Let me know if you understand what I'm telling you.
Feb 07, 2010 | LG 32LG30 32 in. LCD HDTV
Analog VCR Model SDV394SU on cable will tune stations and record the current station, but will not start for for programmed (on/off timed) recording. In other words, when you program the VCR to start at a...
The answer to your question, "Does this have anything to do with the fact that the VCR and TV are now on cable?" is no.
The outside antenna and the cable are input signal sources only and have no effect on the functions of the VCR.
It sounds like you have an electronic problem with the timer circuitry. In order to locate exactly where the timer circuitry is located, you would need a service manual for your particular VCR. Using the service manual, you may or may not be able to repair it.
My suspicion is that it would be cheaper to just purchase a new VCR if timed recording is important to you.
Aug 07, 2009 | Toshiba Televison & Video
Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
Jun 30, 2009 | Quasar VHQ400 VHS VCR
Can't recorder digital broadcast
Hi,if your vcr is an analog machine then you will not get a signal.If you have a seperate digital box then you can connect this via a scart lead to av2 on the vcr.Best thing though is to buy a digital dvd recorder.hope this is of some help.jamie
Mar 02, 2009 | Zenith XBV443 DVD Player/VCR
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Jan 12, 2009 | Insignia Digital-to-Analog Converter for...
How do I use my VCR with the DTV Converter Box that I had to get?
You only have three choices that I know of. The first two are a bit expensive though. 1) Buy a digital TV, then you could split your antenna cable to the TV and Converter box. Then use the converter box as the tuner for the VCR. 2) Buy a digital VCRand do the same thing using the converter box as the TV's tuner. or 3) Get a second Converter box and split the incoming cable between the two, using one for the TV and the other for the VCR. If you use any of these ideas, remember that You need to not have the VCR and the "new" tuner for the TV set to play on the same TV channel, and that you switch teh VCR out of VCR mode with the TV/VCR button, so that you get a clear signal on the other channel. If anyone has an easier solution, I too would like to know about it, seeing as I am in the same position and would like to avoid this problem as well.
Jan 02, 2009 | JVC HR-J692U S-VHS VCR
Akai VSG285 video - I can't tune any TV stations thru to the VCR?
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Apr 09, 2008 | Televison & Video
Change recording speed
The only solution to this problem is to buy a new remote from the manufacturer. Aftermarket remotes that I have looked at: RCA, PHILLIPS, SONY, etc do not have a speed select button for the VCR. (which IMHO is stupid) Come on aftermarket people- it cant be that hard to program a speed select button!
Oct 13, 2007 | Emerson EWV603 VHS VCR
Sony SLV-D350P DVD Player/VCR Logo
102 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
