THE SCANNER ON M220 WILL NOT SCAN - Computers & Internet
  • 981 Answers
What's the M220, a freeway?  Is there no error code you found?  Perhaps you can at least search for issues from the maker's knowledge base; before presenting enough details here for someone to see what the problem might be!  Stop typing in all caps too; even if it's using your cellphone, at least do it right and with enough details to distinguish what happens from what should.
Posted on Nov 16, 2008
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
Jun 16, 2011 | Computers & Internet
How may I scan a document?
Overview: To scan a document you need a scanner and scanner software, this answer will cover
the steps necessary to scan and save a document.
  1. You must already either own or purchace a scanner (eg: this model)
  2. Connect the scanner via the provided USB cord. Consult the manual for this step as necessary.
  3. Use the provided scanner drivers (Consult your scanner manufacturer's website to obtain) and scanner utility to preview the document.
  4. Adjust the settings as necessary and preview your document, if satisfactory enter a name for your scan and save it.
Mar 07, 2011 | Computers & Internet
How to scan using an imac
  • Connect a USB or FireWire scanner to the iMac using the scanner cord and the ports on the back of the iMac. Turn the scanner on.
  • Use the CD or DVD that came with the scanner to install any required software drivers. If the manufacturer's instructions indicate the scanner does not require additional drivers, you can skip this step.
  • Put the object you want to scan face-down on the bed of the scanner.
  • Scan the object by pressing the "Scan" button on the scanner. Image Capture will launch automatically and display a low-resolution preview scan.
  • Set up the scan using Image Capture. The settings available will vary depending on the scanner you are using. With most scanners, you can select a specific area of the object to scan, choose a scan profile based on the type of object you are scanning, adjust the color options and set the resolution.
  • Click the "Scan" or "Scan to Folder" button to scan the object. The image will save to the "Pictures" of your home directory if you press "Scan." The image will save to whatever folder you specify if you press "Scan to Folder."
  • Oct 25, 2010 | Computers & Internet
    Won't charge
    if the charger is good, then there is something wrong with the charging port or the battery.
    If the battery is very flat before you charge, the charger would not be unable to wake the battery because the battery cell is weak. Its only a desktop charger that can wake the battery cell.
    So, test your phone with another good battery, and if it still does not charge, then the charging port is bad as I said earlier.
    Best wishes.
    Jan 12, 2010 | Samsung M220 Cell Phone
    Samsung sph m220. how do I remove the sim card?
    That phone is a CDMA phone and does not use a SIM card. Sprint phones and Verizon phones are CDMA and do not use SIM cards. AT&T and T-Mobile use SIM cards, but are GSM phones, a whole different technology/signal. Nextel phones do have SIM cards, and some "World" phones at Verizon have SIM cards for traveling overseas where there is no CDMA, but your Samsung SPH-M220 has NO SIM card.
    Just in case you want to check anyway, here is a link to the user's manual:
    http://support.sprint.com/global/pdf/user_guides/samsung/m220/m220_by_samsung_ug.pdf
    Dec 29, 2009 | Computers & Internet
    My Samsung M220 will freeze every time i try to write a text message
    Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
    http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=01010200&prd_mdl_cd=SPH-M220DAASPR&prd_mdl_name=SPH-M220
    Hope this helps, let me know if I can do anything else for you.
    JimmyC
    Oct 13, 2009 | Samsung M220 Cell Phone
    Driver scanner benq 3300u
    If you have a BenQ Scan to Web 3300U, just plug in the scanner to your USB port on the computer and plug the power into the power bar. XP will recognize that you have connected the scanner to your pc. It will install the scanner immediately.. Go to MY PICTURES. The top option on the left hand side of the screen will be "to obtain pictures from a scanner or a camera". Click on this.. It will tell you that you have a flatbed#23 . Click on next. Using the preview button, scan the document. Using your mouse, make the scan box fit your picture or document. Then click on scan. Save your scan job . You can then view your scan job.
    Dec 24, 2008 | BenQ Scan to Web 3300U Flatbed Scanner
    My hp jet scanner 6200c doesnt scan.
    I lost the CD of the hp jst scanner 6200c, but i down loaded the program on line. However, when I scan nothing appears on the screen and the scanner makes a lot of noise. The light does go on on the scanner but it doesnt scan i get a blank
    Nov 22, 2008 | HP ScanJet 6200C Flatbed Scanner
    Scaner does not scan
    Printer works well, but the scanner will not scan only leaves a black page
    Dec 28, 2007 | HP PSC 2355 All-In-One InkJet Printer
    Computers & Internet Logo
    54 people viewed this question
    David Payne
    David Payne
