Question about E-Machines eMachines Desktop PC
My computer screen got bigger
It got bigger and i try to adjust the settings in properties but its already as low as it can go
  • sk8b0arder94 Nov 14, 2008
    yeah like its already at 1024x768 but like its not as small as it should be and not just my desktop like my internet explorer and everything and its super annoying.
Press Control and + to make it bigger
Press Control and - to make it smaller
Posted on Mar 29, 2011
  • 70 Answers
The higher the resolution the smaller the icons. 800x600 will show large icons with little screen space. 1024x768 will show smaller icons with more screen space :)
Posted on Nov 14, 2008
    President:
  • 1,901 Answers
What do you mean when you say "low"?
Increasing the resolution will usually make your screen smaller. Try 1024X768.
You also have manual adjustments on the monitor you can use to decrease the size, vertically and horizontally. Sometimes the menus are kind of tricky though. If you have the manual check it out. If not, comment back with the monitor make and model and I'll try to help you navigate.
Hi, I have an LG Flatron w2343T and on a recent restart the screen resolution came up all distorted in that all the icons are bigger and my wallpaper photo is enlarged to the point that I can only see...
For some reason your screen resolution changed, to adjust it
Right click on a clear area on your screen, select Properties,
select the Settings Tab, Screen Resolution, adjust to the desired
resolution
Jul 13, 2011 | LG Flatron L2320A 23" LCD Monitor
The picture is too big for the screen. The four buttons will only adjust colour and contrast - not size
To adjust the screen size (resolution) you have to right click on an empty place on Desktop, select Properties and then Settings. Under screen resolution change it to more, until it shows under it 1024x768, or even bigger if you want and it is possible.
Dec 22, 2010 | Packard Bell 15".28 1024x768 Beige CRT -...
I am unable to adjust the screen to fit the monitor. The screen is bigger than the monitor and I cannot reduce the size using the menu buttons on the monitor. Is there anyway to use those options through...
Yes right click on the desktop and click properties, when the window comes up, go to settings, and set to say 800x600, and click OK, this may sort you out.
Also ensure you have the graphics manager installed too.
Aug 06, 2010 | LG Computers & Internet
Image set up of screen is only half of the monitor
If you v-size is already at 100% then the issue is with the picture being sent to the monitor. Based upon what kind of input you have for the monitor there is a number of different ways to fix this. I will assume you are using the monitor with a desktop computer. If this is for XP, then there is a simple fix as follows, adjusting your display properties:
Right-click on your desktop background and then click on "Properties" this will open up a new window. Select the "Settings" tab, then drag the green arrow in the "Screen Resolution" field to the desired setting. Since you have a "widescreen set-up" you more than likely have a resolution where the first number is about twice the second number...they should be close to even to have a square image (bigger numbers show more detail than smaller numbers).
Hope this helps!
Jul 16, 2010 | AOC 7F 17" CRT Monitor
I hooked up my computer to the tv and the desktop is bigger than the tv screen can't see the icon or tool bars? res. is set on the max tv menu doesn't have alot of picture settings
Try going into your display properties, and adjusting from there. Right click anywhere on your start screen, and select properties. Then select display properties. Hope this is helpful
Apr 28, 2010 | RCA 36V550T 36" TV
When I maximize my document, it is bigger than the screen
Have you tried adjusting the screen properties via Windows? maybe changing the resolution will fix it, and you can adjust the physical screen size too.
Feb 03, 2010 | Dell UltraSharp 2408WFP 24" LCD Monitor
The color on the screen is too dark and the print is blurry.
Okay, I can really help with this one, lol. First right click on your background and click properties. Now click the settings tab and look for the screen resolution adjustable bar. set it back if you need bigger font. Now for the brightness...if you're on a regular desktop your monitor will have adjustable buttons. Click on them until you can find brightness. If that doesn't work, then I don't know. I'm on my dad's laptop and his is just fine, I don't even know how to change the brightness to this and I know a lot about computers, so try that.
Jan 28, 2009 | Acer Aspire 5610-4648 Notebook
Adjusting the screen resolution
Right click the desktop > Properties > Settings Tab, you can change the resolution in there.
Jan 02, 2009 | Dell Dimension 4600 PC Desktop
Using tv as moniter for games
Try setting the resolution on the desktop when you are on the tv I found that I had this problem before myself and the only way to make it bigger was adjusting my desktop resolution I had also made sure all my settings where correct on my tv as well but I think if you goto the advanced properties on your secoundary or primary if you are using that and adjust the resolution.
are you using VGA or SVIDEO?
Nov 29, 2008 | Computers & Internet
My screen is bigger than the monitor for my toshiba satellite laptop.
Hi.
What is happening is the settings that you have set on your laptop are too high for the monitor to recognize.
You will need to reduce the resolution settings in you display properties which can be found by going to start-settings-control panel- display- and in the display area choose settings.
Some video cards will let you adjust each item. Some you have to use the same resolution on both screens.
Shout if you need furthur input !
Fran
Oct 19, 2008 | Acer AL1916W 19" LCD Monitor
E-Machines eMachines Desktop PC Logo
1,119 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
