Question about Frigidaire ATF6000ES Front Load Washer
Tumbler Washer drum fills with water when unit is not operating.
Regarding a Frigidaire Tumbler Washer Model fwt449gfs.
The drum has been filling very slowly with water overnight. form what I can deduce, the most logical culprit would be a defective water valve.
Am I correct to replace the water valve as the first step?
Thank you!
  • Anonymous Dec 26, 2008
    I have the same problem with mine. Unfortunately I discovered it when opening the door to load it. .....Flooded my utility room.
    The repair man has replace the seal, control board, and door latch assy in attempt to remedy this problem.
    Thankfully I have an extended warranty on it.
  • Anonymous Feb 08, 2009
    I have the same problem. It fills with water during the evening (but not every night). I will check the water valve and see what I can do.
    Sergeant:
    Champion:
  • 262 Answers
Yes the water vale is defective it has goten a little piece of sand of something in it and it dont take much replace the valve and the problem will be gone good luck
Posted on Nov 14, 2008
  • 1 more comment
  • marci gonzalez
    marci gonzalez Aug 20, 2017
    where is the water vale? on the washer?? thanks
  • alaa refaei Aug 26, 2017
    solinoid
    at the end of water inlet hose , washer side
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
At the end of water inlet hose , washer side
Posted on Aug 26, 2017
My Frigidaire stackable laundry center will not fill with water?
Hi Keith Knapp, I appreciate your inquiry!
I understand that your Frigidaire laundry center is not filling with water. It sounds like you could be having a problem within water valve, control board, or door switch. I would recommend having a technician out to your home to properly diagnose and repair your appliance. Hopefully this is helpful. -Matt
Aug 21, 2014 | Frigidaire FFLE2022MW Electric...
Lafw7000lw reviews
Good Afternoon Friend,
I understand that the fabric softener cup in your Frigidaire washer, model# LAFW7000LW, never drains and is filled with dirty water. This is a result of the siphoning action and is part of the normal operation of your washer. You may remove the water by removing the dispenser drawer and draining the water into the empty drum or sink. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Dishwashers
Finding tub filled when not in operation. Frigidaire Affinity- error code e30. Why is it filling on its own?
Hello Cynthia, thank you for allowing me to assist you. Often when a unit continues to fill with water, it is because the water valve or sensor is faulty or the control board is experiencing a communication problem. The unit may possibly think that there is not enough water inside and/or the control board is not controlling the water valve correctly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Aug 15, 2013 | Frigidaire Washing Machines
Water leaking out bottom of drum. Drum does not fill up all the way and starts leaking close to halfway of filling
Contact a professional so they can properly and accurately diagnose the unit for repairs. Sounds like you have a leak in the drain lines, or the water valve.
Sep 01, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire GLTF2940ES Isn't Filling Properly.
How old is this washer? You maybe looking at a defective fill valve (where the hoses on the back connect to), or an obstruction in the pressure hose that leads from the Load Size selector to the fill valve. Also, unplug the unit and check the electric connections on the valve as well as the Load Size selector.
Dec 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
Drum fills with water when not in use
It sounds as though you have a fill valve that is leaking. There are 3 valves on the fill unit, 1 for hot water, 1 for cold water and 1 mix. Either the hot or cold valve in the mixing unit is leaking.
You can take a look at item 39 below, it is the water valve unit.
fd13a43.gif There could be a piece of rust scale or dirt under the valve seat that is causing the leak or it is just worn out.
Good luck, let me know if I can do anything further.
Regards,
Aug 02, 2009 | Frigidaire GLTF2940ES Front Load Washer
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire washer starts to fill then stops
Check the water level fill sensor. Some used to be pneumatic tubes connected to a sensor. Your washer may have a different type of sensor. It seems like it fills ant gets to a point where it expects the fill sensor to trip but instead just stops. Also re check ALL connections to main drive motor.
Also verify your mains power can handle the draw of the rated wattage. When it goes to engage the main drive motor it may not have enough current from the mains and simply stops.
Also check that the connection to the tumbler drum is not frozen.
May 02, 2008 | Frigidaire FWTBB30DS Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
118 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
