SOURCE: cant print pdf file - get first page only
Just to show I'm for real here's the solution
Document security settings dissallowed double sidded printing.
Solution: Return document to author for security changes or just print single sided.
It worked - I did both
SOURCE: Ricoh printer printing error: undefined offending command: mz
it is a logic card problem. so pls checked it from service center.
SOURCE: print error page Bizhub C351
Google the full error.
this sounds like a font realted postscript error.
SOURCE: Help: the printer prints:
Thi sseems to be a post script error, try downloading and installing the brpost script drivers.
Follow the link below for downloading, the instructions for how to download and install are there.
Seems to only be availlable for WIndows 2000, or XP.
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/000200/dlf000239.html?reg=us&c=us&lang=en&prod=hl5150d_all&type2=1&os=7&flang=4&dlid=dlf000239
SOURCE: have a Xerox Phaser 8560
Sounds like a Postscript error.
Try resetting the NVRAM. 'Troubleshooting', Service Tools', 'Reset NVRAM'.
If that doesn't work, go into diagnostics and clear the PS NVRAM.
'Troubleshooting', 'Service Tools', press and hold 'Up Button' then press 'Down Button'.
This takes you into a hidden service menu. From there scroll down to
'Enter Service Diagnostics' and press OK.
Printer will turn off and reboot into diagnostics.
Scroll down to 'Function' menu and press OK. Now scroll down to 'Clear PS NVRAM'
and press OK. Press 'Back' button to return to first menu, scroll up to select
'Return To Customer Mode' and press OK.
Don't forget you will lose all printer settings including your IP address. As you cannot print
out a configuration page, this will be like setting the printer up from new as you will have
no reference to your earlier settings.
Hope this helps.
