Question about Regal Ware 426473 Black Satin Coffee Urn 101 Cup
How to make coffee with 101-cup percolator urn (Regalware)?
I "inherited" the urn but without instructions or manual. How do I make coffee in it? Thanks!
  • Anonymous Mar 13, 2014
    The instructions for how much coffee to water directions blew away. (it was a very windy day!)
  • Julian Wynn
    Julian Wynn Mar 27, 2014
    My instructions were just thrown away two days ago after the last time we used it for a small reception. I do remember that the instructions said for 80-86 cups, use 5.5 cups of coffee, so the below answer seems a bit mild. You can experiment with what the booklet said and the recommendations of Rosylu (1 x 8-oz cup per 20 cups) and get it to where you like. I do remember that the coffee was a bit strong, so I'll probably back it off by at leas a half cup of coffee the next time I make 82 cups)
Simply fill with COLD water to the number of cups desired.
Place the stem and basket in the pot and put one 8 oz cup of coffee for every 20 cups of water into the basket...when doing 100 cups I add an extra 12 oz of coffee for a good coffee flavor.
Place the perforated lid on the coffee basket that is in the pot (if there is a lid--some do not have a lid). Put the cover for the coffee pot in place.
Plug in.
Turn on if there is a switch.
Give these large pots about 1 minute per cup, brewing time...that is a little over an hour usually to brew 100 cups. The coffee maker will percolate with the water coming up through the stem and over the coffee as the water heats. Usually there is an indicator light that comes on when it is finished.
If holding the coffee for awhile, it tastes best if you remove the stem and basket and it will maintain the heat without doing more "perking" and becoming stronger or bitter.
Be sure to wash it out and dry it well, leaving the lid loose or upside down for storage so that the pot doesn't become pitted. Blessings, Louise
Posted on Jan 15, 2009
I need an instruction manual for my Farberware 36 cup coffee urn.
Hello!
I think that this instrucion manual will work for you: http://www.useandcaremanuals.com/pdf/FSU122.pdf
It would help if you mentione the model of the coffee urn.
Greetings!
Mar 25, 2016 | Farberware Coffee Makers & Espresso...
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
How much coffee would it take to make the 55 cups in this coffee maker, and can you use the same coffee as you use for drip machines?
Your model sounds like the West Bend 59055 - Large Coffee Urn, 60 Cup.
The User Manual for your coffer urn can be found here:
http://www.westbend.com/supportdata/L5613B_LargeCapacityUrns-All.pdf
Instruction for making coffee can be found on page 5. For 55 cups is would take 3 1/4 cups of coffee.
Use an electric perc or regular grind coffee; if you grind your own this should be a medium to coarse grind.
Do not use 'drip' or finely ground coffee as this could plug the drain holes in the basket and cause the urn to flood.
Mar 24, 2011 | West Bend (59055) Stainless steel 60-Cup...
Where can i find parts for a regalware k1355 55 cup coffee urn
I have a Regalware 55 cup coffee urn, model #K1355. I do not have a part's list for unit. The part I'm looking for is a small switch. It says WR-I think that stands for White Rodgers. It's a four terminal switch two terminals on each side. The numbers on switch are161491 085n, other numbers on switch are250c, 158E,andTf318c. can you help me find this switch.
Jul 31, 2010 | Regal Ware (RW58230R) 30-Cup Coffee Maker
Looking for percolator tube for 90 cup urn
Hey, sorry I don't have a solution, but a question! Do you still have the manual?? I have the same maker and woudl like some advice on making 90 cups of coffee before I have caffeine deprived angry guests on my hands.
Jul 28, 2010 | Lancaster Colony Deluxe Coffee Urn 58 Cup
Instruction manual for Bakers & Chef 60 cup coffee urn. I need to know how much coffee (in cups) to make 60 cups of coffee. I misplaced the instructions that came with the coffee urn. Thanks, Tom
I use 1/2 cup ground coffee for 12 cups. I make for the church and guests and everyone seems to like it. I use the same amount for decaf or regular. Hope this helps.
Oct 02, 2009 | Coffee Makers & Espresso Machines
Regal Ware 426473 Black Satin Coffee Urn 101 Cup Logo
3,288 people viewed this question
Top Regal Ware Coffee Makers & Espresso Machines Experts
Tom Chichester
ray gallant
Are you a Regal Ware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
