Question about Emerson MW8102SS 1100 Watts Microwave Oven
Microwave shuts off after 2-5seconds
When i turn it on it runs for 2-5 seconds and then shuts off and goes to the clock setting mode. HELP cannot live without microwave
  • 5 more comments
  • madchemist24 Jan 22, 2008
    YEP, same problem ... sort of. everything mentioned and more.
    My micro is 2 years old ... and out of warranty. Last weekend the fan came on by itself early in the AM. I tried to turn it off...then noticed the digital display saying to reset the time. I thought we lost power in the over-night. I rest the time and within 5 minutes, the fan was running again and the dispaly said to reset the time. This went on a few more times, the the silly machine accepted the time and everything was fine.
    Later that night, it happened again. This prompeted me to dig up the orginal paperwork. I found the user manual as handy as everyone else. I tried to un plug it and allow for a reset. That seemed to do the trick. It lasted about 4 days before falling into the pattern again. I "reset" it again. Now today, I was heating a micro-meal sandwhich. I set the time for 3 minutes. A few seconds later, the machine turned off. The fan came on and the display said to resetthe clock. I did. I also reset my timer for three minutes to cook my sandwhich.
    The micro cooked for about 15 seconds, shut down and the fan started again. As I walked back into the kitchen, it was smoking from the vent and smelled of electrical melt-down. I unplugged the unit. It continued to smoke for a few more minutes before it was done.
    LG was not very helpful when I called them, They seem to think that two years is good for a machine with a 1 year warranty. I was not amused considering the unit I replaced this one with was 15 years old and still worked.
    Though I need one, I am hesitant to buy another.
  • Anonymous Feb 20, 2008
    Mine is a GE Spacesaver above range model. It is about 2.5 years old. When we press cook time, no matter how long, and whatever power level is selected the microwave will start, run from 3 to 5 seconds then stop and the display will go blank, it will then give the welcome to GE message asking to please program time and date. I have unplugged and let it sit. I have checked possible filter issues. Nothing has worked. The problem has gotten progressively worse to now it does not work at all.
  • Bennyjoe Jun 13, 2008
    My is GE JVM1440BH03 Serial 900839B 2005 model.
    The units runs and heats for 3 - 4 minutes and completely shuts down. Allow it to seat one hour or so and it will start and run 3 - 4 minutes and completelly shut down again. Also, there is a different sound than when it ran fine.
    Benny
    srcx007@bellsouth.net
  • bigitt Jun 16, 2008
    my microwave lamp is very dim and also the table turns very slow and it does not heat up
  • shirlewis Sep 13, 2008
    Exactly the same. After re-setting the clock it works for two or three seconds and shuts itself down.
    Joe Lewis, Birmingham AL sajolewis@charter.net
  • Anonymous Feb 09, 2009
    Same problem. Panasonic NN-H965WF
  • jm_hanna Feb 21, 2009
    I have 2 units and they both do the same thing---run for 3 seconds and shutdown or reseta Panosonic and a Sharp.
    I am pretty clever but I am stumped---Help!!!!
The problem is most likely the magtube, it takes aprox 3 sec for the tube to energize and then it kills the microwave. If you drop the control panel away and start the microwave 90% of the time it will cook fine.
Posted on May 16, 2007
My GE spacesaver did the same thing. It was the magnatron leaking. The tech had me remove the control panel screws and tilt it out. It ran fine, but would then flicker and quit as I moved it back to the normal position. Part was under warranty. Cost about $50 labor when i took it to the tech.
Posted on Feb 14, 2008
  • Emerson Master
  • 9,156 Answers
That means the power to the whole microwave or to the control panel is being interrupted. Most models have a wiring diagram inside the cover which shows you the path taken by the power. I would suggest you look over my important safety and disassmebly texts by searching on Yahoo.com (not Google) for microwave circuit repair safety.txt
Posted on Nov 20, 2006
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
Microwave doesn't start but the interior light goes on when you hit the start button
Hello
Remove the plug from the wall outlet and wait about 10 seconds before re-inserting it. The plug must be firmly inserted to transfer electricity to the appliance.
Open your home's circuit breaker box and reset the breaker if it has tripped and is set to the "Off" position. Simply slide the breaker over to the "On" position to fix a breaker that has tripped.
Plug a different appliance into the same outlet to make sure the outlet you are using is functional. Plug the microwave into a different outlet to see if this yields different results.
Press on the microwave door to ensure it is completely closed. The microwave will not function until the door is fully shut.
Press the "Start" pad on the display panel after setting the time. Failing to press this will result in the microwave not knowing that it should start.
Press the "Stop/Reset" pad on the panel if a program different from the program you want to run has already been entered into the system.
Press the "Clock" pad three times to turn off the demo mode. The demo mode will not allow the appliance to turn on and cook as it should.
Oct 04, 2011 | Microwave Ovens
The light inside goes on but the microwave doesn't
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker shuts off after a few seconds and asks for the clock to be reset
Ge Spacemaker comes on ok but after a few seconds the noise level goes up significantly and it does not heat. It keeps running until the time runs out but it doesn't heat.
Feb 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave only runs for about 3 seconds.After
Chances are you have a failing magnetron.
But to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "Microwave only runs for about 3 seconds then stops and the timer goes back to the clock mode.After several attempts then it will work.Problem is intermitten"
Dec 04, 2009 | Panasonic NN-S252WF Microwave Oven
Microwave wont start but timer counts 3 secs and shuts off
Check the door latch mechanism the black nylon door catch may be broken.
Jun 19, 2009 | Panasonic NN-T993SF Microwave Oven
Demo Mode
Unplug the microwave for at least 3 minutes, then plug it back in, and BEFORE SETTING THE CLOCK, press and hold power level and start for three seconds. This should flash "demo mode off". Set the clock as normal. Enjoy!
Mar 31, 2008 | GE Advantium SCA2000B Microwave Oven
Timer Shuts off after 5 seconds
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Is it 5 seconds or 5 minutes? The difference coulsd be important, but either could indicate a bad magnetron.
Let us know if the hard reset doen't fix it.
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 18, 2007 | GE JES1289SK Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
1,302 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
