Question about Compaq Presario C700T Notebook
Dvd player my dvd player is not working when a cd is placed inside it does not loads it
At first clean the lence eye,but not ok then change lence rebon wire >change lance> loading ic(cheeps) ok> chek power supply board.
Posted on Nov 23, 2008
I cleaned my dvd player tested it working fine. Watched a movie. Put it back together now just reads loading.
Someting in the player intake can be not timed a microswitch or switch contact s inside the tray that will see if a cd is loaded is not timed or not finishing that it not let see the signal to get focussing the table of contents of the cd , a slipping belt or what ever . a dirty mode select switch in some kind of players with more cd or dvd .
if the cd rotating if loaded then it goes focussing for the reading mode .
cleaning or replace belts contactspray inside microswitch or contacts inside the disc tray.
Mar 24, 2016 | Televison & Video
Protable phillips pet824 DVD player will play cd but not dvd's
follow this steps, and fix it. Merry Christmas.
However you must sure if you device can play any CD/DVD.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Dec 17, 2013 | Philips Televison & Video
Sdv395 will not open
There are two possibilities for this fault. The first one is of its loading belt. If loading belt, that fastened to loading gear wheel to loading motor get loose or broken, the tray won't come out or go inside. Just place your ear very near to the player, and push eject button and listen, whether there is a motor running sound for at least 3 seconds. If you hear this sound, make sure that the belt is brokenn. The second chance is with loading motor itself. If it do not get proper voltage or got dmaged, the fault you describe here will occur. To replace this motor, you have to disassemble the CD mechanism. You must have all the tools to do the work and experience to disassemble and reassemble the CD mechanism. The motor is not a costly part, and can be bought from most of the electronic spare part selling shops at your town. OK.
Jan 03, 2012 | Toshiba SDV395 DVD Player/VCR
When loading a dvd it displays, "NO DISK". Is it
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
Wont eject my cd
Try pressing repeatedly the eject button while you turn on the unit. If it does not work
then it is a mechanically problem in your player.You need to be manually open to take out the dvd.
The rubber thread which should be connected to the motor inside the DVD player might have moved from its place.You need to place the rubber thread to proper place.
Hope this helps.
Feb 11, 2011 | JVC KD-G200 CD Player
My 4 year old APD 3955 stopped working. You can
Check the lens, sometimes dirt gets in there. Try to run a DVD cleaning disk... they are sold at many places, they are cheap and you can still use them for cleaning your CD players and DVD players at home. This should fix the problem.... if not ... try to shake the DVD player gently to remove any foreign matter that could be stuck somewhere...good luck!
Jun 05, 2010 | Radio Shack Accurian APD-3955
CD/DVD drawer won't open so CD stuck inside :(
Well you can please follow the below steps -
1. Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
2. Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It's the part that holds the DVD loader in place.
3. Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don't want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
4. Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn't quite finished yet.
5. Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
6. Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you're careful. You should be able to access and remove the disc.
Good Luck!! Thanks for using FixYa!!
Feb 03, 2010 | Cambridge Audio Azur 540D DVD Player
Disc shows loading then error on all dvd disc
Put a cd in the dvd player if it is marked that it plays cds... if it plays the cd your dvd laser is shot... cheaper to get a new unit. if it doesn't play a cd try cleaning the laser. and last but not the last thing try unplugging it for a short time then plug it back in... if nothing works get the one tool that fixs most everything...... take it to office depot and they can recycle the stuff inside and help keep the earth green...then onto wally world.
Nov 26, 2009 | Philips DVP5140 DVD Player
Loading but nothing happens
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.I hope this information helps your problem.
Apr 07, 2009 | Mintek MDP-1810 Portable DVD Player
DVD/CD will not load and ejects
junk it and buy a better dvd players fail quickly..
Feb 25, 2008 | Durabrand DVD-1002 DVD Player
Compaq Presario C700T Notebook Logo
24 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
