Question about Sony KV-27S42 27" TV
Dropped TV!!! Hi, Unfortunately just dropped my TV... Not smart, but mistakes happen. Not time to sort out the damage. The TV fell from about 1-2 feet directly onto the front side. Upon trying it out, the led flashes as usual but instead of turning on the image, one can hear a click and the TV shuts down by itself. I inspected the TV, found a small crack in the big board but one that doesn't seem to disrupt any connection. Otherwise, no obvious damage. What is the most likely problem? Other crack in the board? Tube broken? Is it worth fixing? Sad consumer
  • 24 Answers
Worth fixing? Sorry, probably not. My experience with problems like this are such that the set will keep being repaired as new issues develop. The click and shutdown are a safety feature and are kicking in for a reason. Take what you'd spend on repairs and get a new TV. It will be cheaper in the long run. You might make some $ back by selling the set for parts. Who knows? Hope this helps.
Posted on Nov 19, 2006
How to get rid of a double screen
Is your tv from 4 years ago? if so there was a rash of tv's having double screens lasting 10-15 minutes. Unfortunately it might be out of warranty. but if it's a newer model, check with samsung (a painful experience) but necessary to get some sort of refund.
Oct 18, 2015 | Samsung Televison & Video
Nikon d3000
did you try a different lens if you did send your camera in for repair . the lens gets damaged easy
Feb 07, 2013 | Nikon D3000 Digital Camera
Hi I have a Panasonic 36" TXPF10 TV. THERES different colors on the screen like a SPECTRUM, is there anyway of fixing this
Its what we call a purity problem on this 36 inch set and only two things cause it, the set (not getting too technical) uses a single part connected inside that when set is turned on powers a large coil around the picture tube--it just demagnetizes the tube---what happens is there is a single black square part there not much bigger than a cube of sugar---easy to spot as it will have three leads in a triangle shape---
What you will likely find if you can get the set apart---Its a real heavy set is follow the power cord to the board---real high chance you will find one of the three leads on that part has broken loose from the board, happens from all the heat at turn on that part gets real hot for a very short time.
You would be smart if one lead has come loose to solder all three---the part is often referred to as a thermistor--as it gets hot it cuts voltage off to the coil.
The other possible cause is only possible if set fell forward or was dropped, in that case the damage is fatal and cannot be repaired.
Let me know if questions.
Dec 11, 2012 | Panasonic TX-36PF10 TV
OAKLEY ROKR fell in water- will not turn on- can anyone repair ? Lozomex are you available
If it was fresh water then it could most likely be saved but due to it being salt water unfortunately it will not be possible as the salt is very corrosive and will have done damage to the electronics.
Mar 06, 2012 | Oakley O Rokr Pro Sunglasses
My screen turned into all colors after i dropped the tv
HELLO
If the colours on the screen are like a "rainbow" then I'm afraid your tube is damaged - probable cause is the shadow mask in the tube itself has slipped. Dropping a CRT TV set is not good and all sorts of things can happen to the tube.
Carrying monster TV's like this you should always have TWO people carrying it - put it down to experience - you have learned the hard way!
Looks like you'll be buying a new TV!
Nov 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv was fell from wall unit. no power
Check for PCB damages,check for CRT damage.Not worth reparing or not repair able becuce of to much dmages.
Sep 13, 2009 | Philips Magnavox 20MT133S 20" TV
Playstation 2 will load the game, but then only show black screen
You might of had one of the wires connected from the TV to the PS2 damaged and may need new ones or just make sure that the wires connecting each other from the TV to the PS2 are well connected. My little brother use to drop my PS2 a lot too and that happened to me once, but it turned out to only be that the wire got pulled too much when it fell and it disconnected from the TV to the PS2 and I had to only put it in well.
Apr 07, 2009 | Sony PlayStation 2 (PS2) Console
Regarding RECORD button is not functioning
Unfortunately only way is to replace control unit.
Jun 07, 2008 | Sanyo VPC-HD1 HDV Digital Camcorder
Broken screens
Yes, I've seen this happen twice, similarly. When enough shock has been applied to a phone, such as your case, the screen is very susceptable to damage and will need to be repaired or replaced. There's nothing you can do with expertise or spare parts unfortunately, you may even want to look at a new phone if the warranty is out on the phone. Sorry to be the bearer of bad news.
Sep 07, 2007 | Sanyo Katana SCP-6600 Cellular Phone
Sony KV-27S42 27" TV Logo
57 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
