Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
NEED TUBE DIAGRAM FOR PROHEAT 7920
HAS ANYBODY GOT A DIAGRAM OF THE TUBING ARRANGEMENT FOR A PROHEAT 7920.WHEN UNIT IS SWITCHED ON THE SOLUTION COMES OUT WITHOUT THE SWITH BEEN PRESSED.
  • 3 Answers
Hi There!
Here is a PDF link for a Bissell Service Center Repair Guide. Hope it helps! Juli ;)
newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Posted on Dec 01, 2008
My Bissell 7920 pvs tube is split and I need to replace any one have any instructions how to do it!!!
Hey, sorry to hear you're having a problem with your machine. You may want to a qualified technician at one of our Authorized Service Centers assist you with your machine.
Here's quick link to locating one in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 18, 2013 | Bissell 7920 ProHeat Pro-Tech Upright...
Can't get my bissel steam cleaner to sucktion
Check on board switch for tools only or vacuum, is switched to vacuum, as majority of vacuum suction power is diverted to hose/ hand held devices. See if vacuum hose has suction as well? The unit may be clogged with carpet fibresas well and the unit may have to be taken apart and cleaned thoroughly.
Apr 16, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
How do I take apart my Bissell 7920 ProHeat Pro-Tech
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Jul 16, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Change belt on 7920
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
cvzncbn
Mar 29, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Problems--No solution spray
Is the smart mix valve turning and stopping where is is supposed to, if it turns all of the way around, then it is broken inside the top cover. Try replacing the smart mix bottle insert and cap asm part #2101795 . Make sure that the rubber gasket is on the valeve asm. at thebottom of the smart mix bottle. If not, it has to be on the valve.
May 19, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
NO SOUND
You posted in the wrong section, you will need to repost.
May 11, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
411 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
