Question about Baby Lock Esante
Not picking up the Bobbin thread
Was sewing fine and then bobbin thread was low, wanted to finish embroidery so kept sewing a bit more, upper thread wound around bobbin locked up the machine and broke the needle. clipped all the threads, and cleaned out the bobbin case, and feed dog area, changed the needle, tried different kinds of neeedles. Will not pick up the bobbin thread at all, just get big loops of upper thread under fabric.
  • Anonymous Mar 31, 2014
    Thread not being picked up by needle
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Posted on Nov 17, 2008
  • Ruth
    Ruth Dec 02, 2013
    How do you tighten the bobbin case?
I sewed a support seam on neck line. got the bumpy stitches from bobbin. rewound bobbin, threaded machine. went to sew and now nothing works. it wont sew.
Not quite sure since the symptoms are not clear. "Bumpy stitches from bobbin"--does that mean there were thread nests on the bobbin side of the fabric? That is thread nesting or bird nesting resulting usually from mis-threading, upper thread not completely seated in tension disk, or upper tension too loose. Remove the upper thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning--verify the thread path is correct. Set the upper tension to the midway point between high & low number and retest the machine. (Upper tension may need to be tweaked because fabric, thread, and age of the machine will have an affect.)
Check that the bobbin is wound smoothly--no lumps, bumps, or thread ends/pieces sticking out of the bobbin. Check that the bobbin is installed in the bobbin case correctly (turning the proper direction) and the bobbin tension is threaded completely.
If the upper thread is not picking up the bobbin thread, make sure to install a brand new needle. If it still won't pick up the bobbin thread, then the machine's timing has probably been knocked out of alignment. Search for sewing machine timing or take it for service.
Jan 14, 2017 | Sewing Machines
I have a Bernina 145 S activa and I can't get my satin stitch to work , it brings the bobbin thread to the top , what can I do ?
Do you use stabilizer when you are satin stitching? I had a teacher who also hooped the fabric with a spring-loaded embroidery hoop (turned upside-down under the presser foot so the fabric is flat against the needle plate) that would keep the fabric taut.
It is not uncommon for bobbin thread to rise to the top when doing embroidery, satin stitch, etc., especially if you are using lighter-weight thread than usual. You would normally loosen the upper tension so the upper thread will sink into the fabric. However, if loosened upper tension is not doing enough, you may need to adjust bobbin tension when doing embroidery, applique... You might try tightening the bobbin tension just a smidgen to get the bobbin thread to stay below the fabric. Be sure to mark the bobbin case before making any adjustments so you can return it to the original setting when finished with the satin stitch. (If you do a lot of satin stitch or applique, etc., you may want to invest in a separate bobbin case that is set up only for doing that kind of work--saves having to alter the bobbin tension frequently.)
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Mar 16, 2016 | Bernina Sewing Machines
The machine is pulling through more bobbin thread than embroidery thread
Sounds like a tension issue. Try rethreading the upper thread first and then lower the upper thread tension.
Jan 27, 2013 | Brother PE770 Computerized Sewing Machine
Brother Sewing Embroidery Machine
I agree with sylviaivie about find another repairman, they are suppose
to guarantee the work they do.
when the upper shaft is replaced & then the machine is retimed
the machine should work just fine.
but just don't take it back to that man to be repaired
here is a tip if it happens again,,
always try to cut the top thread first,
& turn the machine up on it's back to access the bottom cover
take the cover off the bottom to get access to the bobbin thread
where you can cut the bobbin thread
then you should be able to get the needle out without breaking it &
damaging the upper shaft, replace the needle & make sure
that the thread is good quality & not knotty, clean out the bobbin area of lint or thread
always change the needle on the embroidery machine every project
make sure the bobbin area is kept clean of lint or thread
clean under the needle plate at least once a week for lint if you
embroidery everyday or just often
Aug 01, 2012 | Brother Sewing Machines
Model PE-180 not picking up bobbin thread
Possible that the shuttle settings are not correct. remove the bobbin and thread it once again. reset it back on the catch and see if the thread is caught up. follow the directions once again and make sure the thread is freely moving within the bobbin.
Dec 07, 2011 | Brother Sewing Machines
My bobbin thread keeps coming to the top of my fabric during embroidering on my Singer Futura CE350, I've tried bobbin embroidery thread, regular embroidery thread and clear nylon thread, I've tried...
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
Oct 23, 2010 | Singer CE350
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Dec 28, 2008 | Baby Lock Ellure
Tension on upper thread?
It sounds like the machine needs to be timed, seek out a sewing machine repair shop for this service.
Jun 07, 2017 | Baby Lock Ellure
Sewing Machines Logo
544 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
