Home | Shuttle | AV40S Motherboard | No boot...no not...
Shuttle AV40S Motherboard
Problem for Shuttle AV40S Motherboard
No boot...no nothing...I am screwed
By CCCC on Nov 19, 2006
I am having a huge problem...
I took the heatsink off of my CPU in order to replace it and while it was off, I was on the ground to look inside the case and my foot hit the surge protecter, powering it on. The computer came on for about twenty seconds without the heatsink on the CPU and then shut off. I put the heatsink on properly and then attempted to turn the computer on, but the fans twirled for about half a second and then...nothing. There is a red light on at the top right of the Mobo, but I cannot find out what the light means...HELP!!!
Same Problem
Apr 13, 2008
-   just install the aopen Motherboard Model MX4GVR-GN and it will not power on. I do get a red light on the motherboard itself to come on (standby lights up only). pressing the power on button I get nothing at all. Why? I removed all components and checked the power on button wires-they look fine. what else do i need to do to get this pc up and running?-   lj386
Best Solution
posted on Feb 14, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
pull the cmos battery if nothing posts, put the battery back in after 30 sec., this may help your problem
Solution #2
posted on Jan 16, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I guess you have a real problem now!
First of all never work on a pc without unplugging the power cord!! so you can avoid an accidental start-up of the pc.
If (I think) it's a AMD cpu this can be overheat in very short time when not using the heat sink!
Maybe the cpu is DEAD
Solution #3
posted on Nov 30, 2006
Helpful)
Rumburak
Rank: Master
Rating: 87%, 52 votes
The red light indicates that that the ATA bus is set up properly, (same goes for many SCSI controller cards). On some mainboards it represents memory modules being under current.
If the CPU was and AMD, then it is most likely history. Intel had thermal throttling much earlier, so it most likely is still OK. If your motherboard speaker is present or a functioning one is connected, it should report a dead cpu by a number of beeps.
Check the cpu orientation and/or seating. (make sure you did not damage the cpu ceramic core when installing the heatsink -that killes most athlon/duron and P3 socket cpus)
Was this helpful?
Yes
No
Solution #4
posted on Aug 23, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
You can buy another 754 socket Turion processor on ebay pretty cheap if you fried your CPU. I think my CPU is overheating/overheated, as mine will power on for like 20 to 5 seconds and just shut off.
Popular Solutions for Shuttle AV40S Motherboard
Questions and Unsolved Problems for Shuttle AV40S Motherboard
Do you recommend Shuttle AV40S Motherboard?
Answer
Answer
no audio driver. when i open my music there is a error found. said- bad directsound driver: bla bla... (More)
Answer
Hi i need a new motherboard model no W340UI and another model number on the same laptop MT3107b
Answer
it not work with my computer i asked for a pin number,can you help me ,sir mad
Answer
nesecito resetera la placa madre a7n266-vm
Answer
Bonjour, ma carte mère AV40S V3.1 refuse de me laisser réinstaller xp il semble... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Shuttle AV40S Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14780
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
