While driving in the daylight the DRL's work and the dash shows no warning lights. As soon as the headlights are turned on all of the dash warning lights(ABS,Ebrakes, battery,low coolant,oil pressure) come on and the temperature gauge and tachometer drop to zero. When the headlights are turned off everything goes back to normal except for the DRL's. There is a proven instrument cluster, a reflashed PCM and a new headlight/signal switch installed.
SOURCE: no low beam, headlight on warning sounds w/lights on auto with key out
Had the same problem on a 2003 vibe- finally dianosed as a fried headlamp module then needing to trace back and find a short in the electrical that blew headlamp module . Module $ 170. Labor to replace module 2hrs. Labor to trace short 4 hrs??? Dealer charged me $900- .
If anyone has info on how much time it should have taken. I would appreciate the feedback
SOURCE: 2002 sunfire Drl problem
check wiring in front of washer bottle and harness will lead to passanger side follow it open up harness ussually broken wires inside causing dim or no headlights.
SOURCE: High oil pressure reading
Hi, this is a oil pressure sensor malfunction. the gauge is getting a distorted reading from the sensor. replacing the gauge will fix this issue. also, check the fuse box for blown fuses.
SOURCE: DRL problem with 2004 Sunfire
wraun_1962 .......your DRL relay is in your fuse panel on the left side of your dash open drivers door to access it
