Hi I've bought my headset 3 years ago Recently when I connect it to my phone (or my lap top) after few seconds Bluetooth connection failed and my headset stop working I can't fix it anyhow Please help me Thanks
SOURCE: connecting JABRA BLUETOOTH to MY SIDEKICK 3
Use your Bluetooth wireless headset or car speaker to make and receive calls: 1. Follow the manufacture's instructions for your Bluetooth device to make sure it is turned on and "visible". 2. From your Sidekick, go to the Phone application. 3. Make sure your Bluetooth device has paired with your Sidekick device by pressing MENU and selecting Settings > Pairing. (If you try to do this and you don't have Bluetooth services turned on, you will be prompted to turn it on.) 4. On the Pairing dialog that appears, make sure your Bluetooth device is listed and has a key icon next to it. The key means that it's paired with your device. If it doesn't have a key, roll the TRACKBALL to select the device name, then press to pair. Once paired, press DONE . 5. Back at the Phone screen, press MENU and select Transfer Sound to > Bluetooth Device Name. 6. Dial your number and send the call. All sounds will be routed through your Bluetooth device.
SOURCE: Unable to Detect the Jabra BT125 headset from any Bluetooth Device
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
SOURCE: Need PIN code to re-connect Jabra BT350 Bluetooth Headset w/phone
I had the same problem-- i asked a verizon wireless guy and he said it's almost always four or six zero's so "0000" or "000000". Hope it works for you!
SOURCE: jabra bluetooth headset
If you are having problems with the pass code 0000, try taking the battery out of your phone for 10 seconds. Then try connecting again using the pass code 0000. I just tried it and it worked!
SOURCE: Jabra BT125 headset not connecting to Samsung F480
you have to switch the bluetooth headset to pairing mode not just swithcing it on. Hold the power on button continuously even after it switches on then the light will remain on. Then you switch on the bluetooth in the mobile and start searching for bluetooth devices. You will find your bluetooth headset in the mobile. Select it and pair. Usual code will be 0000, but it might differ check with the manual which can be found online too. This will definitely solve your problem.
