Question about Canon PIXMA iP1800 InkJet Photo Printer
The ink absdorber is full (iP 1800)
Can I resove this problem myself? Can I get any instruction please?
  • 3 Answers
All you have to do is open the casing carefully and be aware of how you're going o put everything back into place. remove the ink absorber, wash it with detergent and water then let it dry. be careull not to crumple it. hen put it back. i did the same o my pixma1880
Posted on Jan 14, 2009
In printer canon ip 1800 is showing ink absorber is full cant use the printer
Hope you find this information helpful.
The printer has a built-in ink absorber to hold the ink used during Print Head Cleaning, for example. Eight flashes indicates that the ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer. Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced
Mar 31, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip 1800 full tank
Reseter Printer Canon IP1880 To reset manually Ink Full Tank, try these methods :
1. Turn on Printer Canon iP 1880
2. Push and Hold resume button about 2 minutes
3. Release resume button
4. Printer will back in normal again
5. Then use the software.
6. Good Luck friend
7. If you want this permanent, Please Download Reset Tool
8. Reset tool support Canon iP2500, iP 1800, iP 1100
For more details visit the following link
http://indoresetter.blogspot.com/2009/04/reseter-printer-canon-ip1880.html
Feb 09, 2011 | Canon Office Equipment & Supplies
ESP-5 will not clear low ink message and print after refilling black cartridge.
chip on cartridge has to be replaced as you can not use any cartridge twice. but for two bucks you can get a new chip to put on your cartridge so you can refill
fillerserv.com and 123refills.net you can buy these new chips for 2 bucks you have to get one for the color and one for the black. good luck!
Jul 18, 2009 | Kodak ESP 5 Printer
My Canon IP 1800 cannot recognized the Black ink
It sounds like the electrics on the back of the cartridge have failed, replace with a new cartridge, and away you go.
Jun 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip1800 ink absorber is full, cannot remove Cartridge
Hi ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps ... Cheers :)
Jun 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My ink absorber is full. i have a canon prixma ip 1800. what can i do
it so easy to solve go to EEPROM.com find the canon Then download the software fit to your printer..
Jan 04, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip 1800 refilled ink says ink has run out, it's full
Here's how to reset the printer so it doesn't give you the out-of-ink message:   1)  Hold down the flashing yellow RESUME button for almost 1 minute 2) Open the cover 3) Release the cartridge(s) (#30 is black, #31 is color), and then reinstall cartridge(s).  Close cover. 4) Turn printer OFF (I had to wait and try this numerous times as green light was flashing & it wouldn't shut off.  Wait, then press OFF again. ) 5) Turn printer back ON, and cheer when it prints.
Dec 11, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Cannon printer pixma ip 1600 ink absorber full
Dear khalid,
To fix this problem you need to reset waste ink counter of the printer by using General Tools for Canon ip1200 series (General Tools for ip1300 & 1800 series also works on this printer)
Perform following step to reset waste ink counter:
  • Enter service mode:
-Plug in power cable while holding power button.
-Press RESUME button twice
  • Connect USB cable (you may also connect USB cable before entering service mode, no problem).
  • Run General Tool
  • Select USB port
  • Click waste ink counter: Main & Platen
  • Turn off the printer then turn on and run your printer as usual.
I think it will be more helpful with picture enclose. For I cannot insert image more than 150 kb here, I suggest you to visit Canon Inkjet Printer Forum. I have discussed this topic before.
Please rate me.
Regards,
Nov 26, 2008 | Canon PIXMA iP1600 Printer
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
54 people viewed this question
old marine
old marine
