Question about Gibson 24 in. MDB632XF Built-in Dishwasher
Dishwasher won't drain
My Gibson diswasher (age unknown) did not drain after the last load. Upon removing all of the water with a shopvac, we discovered a debris which we felt may have been blocking the drain. We tried to run a cycle just to test it out, and now only get a buzz, and nothing else. Is there a reset, or something else to check, or is it dead?
  • Anonymous May 05, 2008
    Same problem here...
  • kswitz Dec 06, 2008
    I have the same problem. I have checked and made sure the drain is not stopped up and still no help. thanks
I'm having this same problem! Any luck solving it?
Posted on Mar 23, 2008
  • 33 Answers
If you add water (by hand) to the dishwasher, does it drain out?
Posted on Mar 30, 2010
SOURCE:
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
No control panel lights on Bosch SGV43A03GB/17 diswasher
i have nearly the same problem ! but my one have no water left in it !but pump still running if i put bucket of water in it will drain it away but no lights on panel and anyone know what that is please ?
May 14, 2012 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Water valve not working and leak under dishwasher
The water leaking causes the float switch to activate the drain pump and as long as there is water in the pump housing area that is the only thing that will run.
Remove the water from below the unit and it should run long enough to trace the leak.
The easiest way to access this is to uninstall the unit and remove the lower back panel. remove the water wih a shopvac
remember to shut the power off.
Apr 01, 2009 | Viking Dishwashers
Hotpoint bf162 built-in dishwasher error codes
take out diswasher, tip it backwards and drain out water. make sure that salt resovoir is on tight and there are no leaks from the arms
Jan 11, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwasher does not drain
If you cannot get the diswasher to drain there is some obstruction in the drain line going to the disposal. First turn the power off to the diswasher at the breaker panel then open doors under sink and follow drain line to the disposal there you will find a hose clamp(silver) that you must loosten with a flat blade screw driver ( get a bucket under the disposal) pull the drain line loose and dump out excess water and debris inspect area going into the disosal to make shure it is not clogged up
reverse your proceedure and reconnect the drain
Before trying the dishwasher take some ice cubes and run thewater then put in disposal and turn on that should clean the disposal
try your dishwasher I forgot to mention that theri is a strainer at the bottom of you dishwasher that you can remove to be sure it is not clogged up I assume that you have aready checked that
good luck
Dec 25, 2008 | Maytag MDB9600A Jetclean II Built-in...
Dish water does not drain
Thank you. Called the company and they are working with us to fix it.
Jul 12, 2008 | Gibson 24 in. MDB632XF Built-in Dishwasher
Diswasher
You will have to test the solonoid electrically now its probably getting juice and the solonoid may have failed. You can get just the solonoid ot the entire pump assy for a little more.
Oct 01, 2007 | Dishwashers
Dishwasher did not drain all the water
Your sink drain is clogged and the back pressure is not allowing the dishwasher to drain competely. Do not use a liquide drain cleaner, it will damage your disposal. take apart p-trap hopefully the clog is there, otherwise the line will need to be snaked.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Sep 22, 2007 | Roper 24 in. RUD4000M Built-in Dishwasher
Dishwashers Logo
180 people viewed this question
Top Gibson Dishwashers Experts
Mike
Marvin
Marvin
Are you a Gibson Dishwasher Expert? Answer questions, earn points and help others
