Question about 2wire Wireless-G 802.11g ADSL Gateway
Unable to open any page
I HAVE 3 COMPUTERS AT HOME. ONE OF THEM IS WIRELESS AND THE OTHER TWO ARE NOT. I CAN NOT OPEN ANY PAGE IN MY WIRELESS DESKTOP. THE OTHER 2 COMPUTERS HAVE CONNECTIONS AND ARE FINE.
THIS HAPPENS APPRX. TWICE A MONTH. USUALLY, THE PROBLEM FIXES ITSELF. HOWEVER, IT IS FRUSTRATING.
ANY SUGGESTIONS?
  • 298 Answers
I think it's better to have this case isolated, since it's happening regularly, I think. Does it say the computer got disconnected from the wireless or does is still have the right address after it stop going online via wireless?
Maybe there is an interference that is causing this issue.
Posted on Nov 16, 2008
If the page does not open then you don't have a connection to the router. Make sure your cable is attached to the router and computer. You can't do the initial install wireless usually.
May 01, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
My Hp Photosmart C5820 all in one printer is connected to my HP Pavilion dv6000 laptop (Windows XP). How do I share this printer wirelessly with my new Dell laptop (Windows 7)?
Any printer that isconnected to a computer and is connected on a LAN can be configured so allother computers on the same network can print to this printer. This means thecomputer with the printer attached to it MUST be booted up at all times whenother computers want to access the printer. You need to install theprinter driver on the computer and configure it as a Shared printer. The other computers on thenetwork need to add this printer to their computer. Follow these steps toset-up a shared network printer :- 1. Connect the printer tothe computer and install the printer driver. 2. Open Printers and Faxes- right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change theShare name, then click OK 3. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation.
Follow these steps toconfigure the computers on your network :- 1. Open Printers and Faxes- click Add a printer - Next - select a network printer, or a printer attached to another computer - Next. 2. Select Browser for aprinter - Next 3. Click on and expand theMicrosoft Windows Network down to the computer with the printer - Next 4. Select Yes for - Usethis printer as the default printer - Next - Finish 5. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation. b>
Mar 04, 2011 | HP Computers & Internet
The wap54G is having issues. Computers trying to connect to it keep acquiring ip address and never connecting. Any advice on what might be wrong?
Hi williamrayes,
If you have a message that acquiring ip address you can Power Cycle the router for 2 minutes then try to connect again or you can try to check if the Network Key that your typing is correct (If the connection is secured). You can check the Network Key of your router by accessing the Wireless Settings Page of your router. To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security, You can personalize the Network Key if your want. Save the settings then try to connect.
Rate me if this helps so I can help others.
Thanks for using Fixya.
Feb 04, 2011 | Linksys Wireless-G WAP54G 802.11g/b...
How do I secure my wireless connection?
The exact access and setting procedure can be found at Belkins web site.
Disconnect all cables to the router, then, in essence you connect to the router, usually via direct connection and direct your browser to the address specified (somthing like 192.168.1.1) and log into the router. Things that you want to change are ssytem ID, router name, Router access password (RECORD IT!!!!) and set up wireless security. An easy access password would be your home phone or cell phone number. if you make a cryptic password, tape it to the router, as you will forget it when a guest visits and needs access.
Another setting to check is that your router broadcasts it's presence, usually set to yes, but not always, by default.
SAVE settings on EACH PAGE or they do not save, as you go from page to page changing settings.
Oct 14, 2010 | Belkin Computers & Internet
Have not idea what my security password is?
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Mar 07, 2010 | Dynex Enhanced-G Wireless Broadband Router
Do you have internet explore ip address. it starts 192"?
what do you mean by internet explore ip?? just your computers IP?? or your routers IP??
normally the IP would be 192.168.0.XX submask is 255.255.2550
but if you just need to know your ip for now just go to START>RUN and type CMD that will open command prompt ( quick way is windows sign on keyboard + R ) to open RUN
once in CMD you type ipconfig then you'll see your IP adress, subnet mask and default gateway. hope this helps
Mar 05, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
Dlinkap web page is not opening
you will have to reset the router
disconnect the power supply and press te reset button for more then 3 second
now you will be able to enter the router with factory setting 192.168.0.1
Feb 13, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
I just set up a netgear router and a lynksys expander. All my laptops work, but iphone & itouch will not. Seems as though the password has changed. Can this happen? How can I find the password? When I...
If you did not configure the Netgear wireless router and changed the default settings and the default password password, then your wireless system is open to anyone hacking into your system and change your wireless router's settings and they can hack into your computers and your Internet connection. The Linksys expander will increase the wireless range to give a wider coverage to your router.
I suggest you reset the Netgear back to the factory defaults (press the pinhole button on the back of the Netgear router until the LEDs flash then release this button,
The configure the Netgear as follows :-
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 13, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
HOW DO I DO I LOG ON MY 2WIRE WIRELESS. I LOOKED AT MY SETING ON PROPERTIES BUT THERE IS ON IP ADRESS OR SUBMASK. BUT I CAN GET ON THE NET. HOW DO GET MY PC TO DETECT MY SETTINGS?
Open a browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.Once you are on the setup page, you can see all your settings.
If you want the wireless key, it is located on the label on bottom of the modem.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Can't set up Cnet CWA-854.
Have you tried changing your IP to 192.168.1.3 and see if that makes any difference
Subnet mask 255.255.255.0
Oct 12, 2008 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
2wire Wireless-G 802.11g ADSL Gateway Logo
37 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
noti13
Level 1 Expert
William Dehn
William Dehn
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
