Sony KV-27S20 27" TV
Problem for Sony KV-27S20 27" TV
Flickering and then nothing
By cuda11 on Nov 19, 2006
Hello, I have a 7 year old Sony 27" CRT Trinitron. The screen started to flicker and the image was compressed from the bottom up. Eventually the image was squeezed at the top of the screen and then the screen goes blank. The entire process takes just a few seconds. If I hit the side of the TV before it goes black sometimes I can get the full image back again for a few minutes before the entire thing starts again. Could it be that there is something loose inside? Should I call a repair guy, or can I check it out myself? Any ideas would be a great help...too close to xmas to replace the TV!
Solution #1
posted on Nov 20, 2006
Not Rated)
rix20601
Rank: Master
Rating: 85%, 42 votes
Well, seven years on a SONY is pretty good. These chassis have a good number of plugs and jacks on the main board. If you feel competent enough to open the back of the set, I'd go to Radio shack and buy a can of electronic components cleaner and a can of compressed air. Then, with the cover removed, find the plug that goes to the deflection coil on the neck of the tube. It should have four to six large wires on it. Disconnect the plug and lightly spray the EC cleaner on the plug and jack. If you have an old toothbrush, scrub the pins where they're exposed. Absorb any excess fluid with a paper towel and then blow the connctors dry with the air. Reassemble and test the set. If this doesn't work, your going to have to probe the other connectors with a wooden dowel rod while the set is on. PLEASE be careful around any High Voltage components!
There's probably a good layer of dust inside the set as well. This layer can act as a blanket and cause components to overheat so carefully cleaning this out with a vacume wouldn't hurt.
Hope this helps. Thanks for rating the solution.
Was this helpful?
Yes
No
Popular Solutions for Sony KV-27S20 27" TV
Questions and Unsolved Problems for Sony KV-27S20 27" TV
Do you recommend Sony KV-27S20 27" TV?
Answer
Answer
Sony WEGA tube 34" 4.5 years old. The picture hue is all green/yellow/blue - no red. When I... (More)
Answer
i have a hitachi 36 tube type tv that the picture is slowing geeting darker. even if i turn the... (More)
Answer
have a 42' tv and i can hear the pictrue but cant see it
Answer
I don't have remote control. How do I use capture (subtitle) function for deaf ?
Answer
I have a 32" (?) Sony TV that is 12 years old. It is a floor model that is incased in wood with... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in Orlando, FL
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
