I have a digital inverter and its not charging the battery now...
I use a digital inverter at home ...............but m havin a problem that its not charging now...............what should i do
    Problem Solver:
  • 4 Answers
Hi! depending on how long you had the UPS the batteries only have a limited life. So lets say you had this UPS for a wile and the batteries are discharged often, the batteries can fail to hold a charge after about three years. If it is likely a year old I would check into the warranty. But three to four years may need replaced and can usually be done by an end user. PS: the inverter may appear not to work at all or just shut down with a bad battery as a safety mechanism. If a new battery or set of batteries does not remedy the problem, then there is a problem with the electronics. If I know the symptom of witch I can help with that as well.
Posted on Nov 21, 2008
Can't find the transfer switch, and could it go bad. Shore power and generator power works to the main panel box, but won't charge coach batteries
although it is possible to do separately most times the transfer switch is internal to the inverter , and the fact you mention that inverter is not charging batteries tells me your fault lay in the inverter all or part of it is not working , look at it carefully these have sometimes two reset breakers on there cases
Jun 01, 2015 | Inverter Electronics - Others
How do i convert my 1.2kw solar inverter on my roof so i can run my home on stored energy ?
Solar panels produce DC voltage.
some solar panels have the inverter integrated into each solar panel.
I would suggest contacting a local solar panel supplier and asking them if they could add a Battery Charging System to the Solar panels you use. An then what sort of inverter to add to the bank of batteries.
An inverter converts DC voltage to AC voltage to use in the grid.
The AC voltages and DC voltages involved have the possiblity to kill if you much around with electricity.
Jan 15, 2015 | Inverter Electronics - Others
Hello I have 40 foot 2006 fleetwood revolution and my problem the batterys would not go into chargeing mode and the red fault stayed lit. And then a electrical smell and shorting noise came out of the...
Your Freedom 458 has died. At this point, you need to isolate the batteries from the inverter / charger unit to prevent further risk of fire.
It is normal, with the fried charger, for the battery voltage to plummet even while plugged in. There is no converter to maintain them. When you start your rig, the alternator on the engine is charging the batteries. With the rapid drop in battery voltage, your inverter likely is shorted.
Remove the main battery fuse between the inverter and batteries, as well as unplug / turn off the breaker to the inverter /charger. Take your coach to the nearet service center, as it may still be under (partial?) warranty.
Aug 30, 2010 | Xantrex Technology Electronics - Others
I buy a new power inverter ERP 2300 12v/220Volts
What does the inverter over 600 Watt.
By what type of battery is the inverter supplied? How many Ah? What is its state?
In order to achieve 1000 Watt for 1 hour you need a fully charged 12 V / 100 Ah lead-acid battery.
If your battery is less then 100 Ah and is not very well charged or old (bad) you may not have over 600 W, but not bacause of the inverter, but the battery.
If your inverter stops due to low input voltage (you can see it in the digital display during operation).
If you want to check the real output power of the inverter you should connect it to a big (more than 200 Ah) well charged battery.
Jul 22, 2010 | PowerBright Power Bright ERP2300-12...
I have a red light on my 360 inverter why
the battery should be low and needs charging or the is no power going into your inverter to charge it
Dec 03, 2009 | RCA Power Inverter
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
Lowering my bill
The best you can hope for is 100% efficiency. Sadly, most chargers are only .707 percent efficient when they convert the AC to DC. So charging the battery is going to lose 30% of the electricity your paying for, even if the inverter is 100% efficient, which they aren't, they are actually probably close to 90%, you lose more money converting the DC power back to AC. Not to mention that the average battery loses 1% of its charge over a month. Your better off just following published conservation topics to save on your electric bill.
Nov 18, 2008 | Xantrex Technology Ags Harness Cable...
Inverter Question
Where can I download Instruction manual for Fuji FVR-E7S?
Aug 27, 2008 | Xantrex Technology Ags Harness Cable...
Re-Charging
is the battery youre tryin to charge a nuckel cadium if so it might be havin memory issue if you kn the model number of battery and or out put and voltage out put DAA-BA0004,
  • Output Voltage: 3.7 V
  • Capacity: 2000 mAh you can try goin here to oder a replacemnt http://stores.ebay.com/Battery-Boy
  • Nov 28, 2007 | Samsung Yepp YP-T9 Digital Media Player
    Computers & Internet Logo
    112 people viewed this question
    David Payne
    David Payne
