Question about Jetway N2VIEW Motherboard
Jetway N2VIEW Motherboard n2view 2 user system solution update wi
Jetway N2VIEW Motherboard n2view pour 2 user system solution update windows sp2 et windows vista
  • Anonymous Mar 26, 2009
pattersj78
  • 70 Answers
SOURCE: new jetway motherboard
the disc that came with the board contains drivers specific to that motherboard.  I would suggest downloading the latest drivers from the manufacturer's website for everything that is contained on the CD.
Posted on Oct 19, 2007
DRSS
  • 81 Answers
SOURCE: Re: Jetway P3 motherboards
http://www.mini-itx.com/reviews/b860t/
Posted on Dec 06, 2007
jell587
  • 447 Answers
SOURCE: user manual motherboard 531CF Jetway Socket 7 SIS 530 / 5595
You should be able to download the manual from this page.
Posted on Mar 31, 2009
AldRezaine
  • 995 Answers
SOURCE: I have a jetway motherboard and usb1 2 3 are not
You can activate the usb function from your computer bios. Turn on your computer and enter your bios by keep pressing the del key on your keyboard. The go to Advance setup and look for usb function settings and turn it on.
I hope this could help you a lot..:-) Thanks..
Posted on Dec 23, 2009
SOURCE: probleme de son pour carte mere matsonic ms9158ep
son du carte mère matsonic ms9158ep
Posted on Mar 09, 2010
No internet network installed???
if you dont have an internet connection
first you must have an ISP Internet Service provider which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the net or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection
hope this helps
Feb 10, 2011 | Jetway N2VIEW Motherboard
Wrt54g2 wireless doesn't get past the acquiring network address point.I'm using wpa2 with aes - wireless configuration is manual.
Unfortunately you did not give more information, so I 'm taking a wild guess here. If this solution does not solve you problem, let me know.
If you are running Windows XP SP1 or SP2, update the operating system to XP Service Pack 3 for best WPA/WPA2 support.
XP Service Pack 1 computers do not support WPA by default and cannot support WPA2. To upgrade an XP SP1 computer to support WPA (but not WPA2), either
  • install the "Windows XP Support Patch for Wi-Fi Protected Access" (link) from Microsoft, or
  • upgrade the computer to XP SP2
XP Service Pack 2 computers by default support WPA but not WPA2.
To upgrade an XP SP2 computer to also support WPA2, install the "Wireless Client Update for Windows XP SP2" (link) from Microsoft.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Sep 30, 2009 | Linksys Wireless-G WRT54G Router
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
Motherboard upgrade??
Dear kaname,
Your computer can support Windows XP, which has better hardware support and compatibility with the 2003 Office suit. XP also updates your hardware automatically once you are on the internet. You might want to try this.
Keep in mind that the older the Operating System, the harder it is for Office suites to compat. Newer Operating systems have better support for your computing. If you don't have HDD problems, the BIOS should not prevent you from loading SP2 for Win2000.
Conclusion:
1. The SP2 Source Disk may have a problem
2. The Win 2000 you have already loaded may be missing components, preventing the SP2 to load.
2. Notton Antivirus versions and the 2003 office both reject Win 2000. They just don't like it; it's getting too old.
Get with it, Kaname!!!!
Feb 27, 2008 | A-Trend ATC 5220 (ATC-5220) Motherboard
Boot problem
Was the operating system installed on another computer? Or a computer with different hardware? If so the drivers for the hardware are not configured properly on the HD or in the BIOS. If this is the case you should format the HD and re-install the OS.
Aug 15, 2006 | Jetway N2VIEW Motherboard
Jetway N2VIEW Motherboard Logo
85 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
