Question about Refrigerators
Water trickeling noise from the compressor area.
I previously had LG model LFC255760 for 1.5 years and had it replaced last week with LFC25770. The old model never had this noise and now the new one has it every time the compressor runs, from the time it turns on to when it turns off. There is a place on one of the lines in the sealed system that has corrosion on it where it looks like it had been leaking and then corroded itself shut. Could this have let air into the system and is causing the noise? Could the system be low on freon?
  • lsmeyer Nov 14, 2008
    Thanks for reply,
    The noise I am hearing is only when the compressor is running and cooling the noise stops when the compressor shuts off. If the noise is freon flowing through the lines is there any kind of insulation or sound deading material that can be installed around the lines?
    Scholar:
  • 66 Answers
If there is a leak in the system you will notice considerable change in temperature of the frig. In most cases, if this is a leak, you will see a builup of oil coming out of the leak as refrigerant has oil in it. You may be able to hear it or smell the refrigerant. What is commonplace in alot of systems is this noise. When the compressor is running, it is biulder pressure inside of the refrigerant lines. There is a low pressure side and a high pressure side while it is running. When the compressor shuts down after achieving the set temp, The system will start to equal the pressure on both high and low sides of the system. Actually the compressor will not start again untill these pressures are equalized or at least close. The noise you are hearing is most likely the refrigerant in the system while the system is equalizing the pressure on both high and low sides. I have noticed that some systems are more noticable than others. Unless you notice considerable change in temp of your frig, it is probably the equalizing of the system. I am not sure what the corrosion on the line would be without actualy seeing it myself but I have never come across a frig that had a leak and didn`t lose all or enough of the refrigerant without it being noticable inside the frig itself. For it to be a leak the temp in the frig should be or very soon will be noticably warmer.
Posted on Nov 14, 2008
  • Charles Caldwell Nov 14, 2008
    I don`t believe this noise will effect the way the frig works but If the noise is coming from the line that goes up into the wall of the frig. You will be unable to get to these lines without damaging the frig.The frame is welded and cannot be dismantled. In the past, for that problem, I have had to have customers call the tech line for that specific brand and speak to them. The reason being if they descied that it cannot be fixed then the manufacturer will have to replace the unit if it is still under warranty. My best advice would be contact the appliance center that you bought it at and pose this problem to them. They will need to look at it and then call the tech support line for that brand.Hopefully you can get this replaced if it is too noisy and unrepairable.
The water will not shut off completly it keeps trickeling in and will fill the drum after a week.
The reason that is happening is because the spring inside of the water inlet valve that is suppose to close it is weak and its not fully closing the valve so water seeps through it into the drum of the washer. To repair that the water inlet valve will need to be replaced.
If ya reply with the model number i will give ya the part number for that valve and instructions of how to replace it.
The model number can be found on a label inside of the door on the rim
GENE
Oct 10, 2011 | Kenmore 44042 Front Load Washer
My refrigerator is six years old and for the past two months is making a loud buzzing noise. The frequency has increased over time. What could it be? It's an Amana side by side model ASD2626HE. Sounds like...
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Apr 12, 2010 | Amana ASD2626HE Side by Side Refrigerator
My GE tfx27f is working fine but when the
the thump ing sound is probably the rubber mounts under the compressor . they go hard and do not insulate the compressor . . pry the comp up on all four mounts and make sure they are loose and not stuck down if ther are hard and not bouncy .. replace them . if compressor has borken internal motor mounts / there is nothing you can do . but put up with noise ..
Jan 06, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Have an LG dehimidifier which seems to have stop working
Could be a failed compressor start relay. They are replaceable. Get one at an appliance parts store for your model or a generic one. Make sure you are unplugged before changing.
Jul 01, 2009 | LG LHD45EL Dehumidifier
Bad Compressor, valve sticking in the compresser
Contact Whirlpool Customer Care about this. There has been a serious problem with the Embraco compressors they are using.
May 15, 2009 | Whirlpool GD2SHGX Refrigerator
Frigidaire humming freezer not cold enough
For the 25 year old freezer: a replacement compressor of the same BTU rating can be obtained and used as a replacement BUT at 25 years old I DO Not recommend the expense of a compressor replacement.
To the owner of the six year old freezer. The buzzing noise is more than likely the compressor cycling on its overload protector. This is an indication that the compressor has failed. In this case also I do not recommend replacing the compressor. If it was in warranty the manufacturer would bear the cost. Replacement compressor come with a one year warranty.
Sep 01, 2008 | Frigidaire FRS26R4A Side by Side...
MY LG DEHUMIDIFIER WILL NOT LOWER THE HUMIDITY
Make sure that the filter and coils are clean. LG recommends that you clean the filter every 2 weeks. They also include a brush to clear the dust from the coils. If this does not solve the issue it will need to be serviced. If it needs to be serviced this dehumidifier has a 5 year warranty. If it is under 5 years old contact LG and they will either offer to have it serviced by a nearest service center or send you a replacement if a service center is not nearby.
Jul 15, 2008 | LG LD65EL Dehumidifier
Mfd2561hes Maytag Refrigerator
This sounds like you have a Maytag Ice2O. You need to find out if that cound is a relay/overoad failure on the compressor or the compressor going out. I can say from experience that some of those have a tecumsie comprossor in them and the do tend to fail. If you hear a loud electrical humming sound coming from the compressor and your getting a warm up then you need to record this sound on some kind of sound recorder and call a Whirlpool warrenty certified tech. out to look at it if it's less than 5 years old from perchase date then Whirlpool will pick up the part and labor bill of a compressor installation also check your owners manual for warrenty details. Hit me up let me know.
Feb 13, 2008 | Maytag MFD2560HES Bottom Freezer French...
Warm to Hot molding that seals the doors
Either the fan motor has gone bad or the coils under the fridge are too dirty. Both will cause a no cool situation and cause this area to become too hot. Part of the coil runs thru the cabinet in this area to prevent sweating. This is a good indication of dirty coils or a bad/weak fan motor. If your fan was noisy I would replace it before it goes out completely. This excessive heat will lead to premature compressor failure.
Nov 11, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
