Question about Dell Computers & Internet
Dell d600 wont boot up, no last known good, no safe mode, only blue screen system shut down to prevent further damage. DST diagnostic test fails. 1 beep 4 beeps 2 beeps
  • Willliam Lafferty
    Willliam Lafferty Nov 14, 2008
    Thank you,that was what my suspicion was also, have no recovery disk now, will get one and proceed from there. This is my first time using this site, could come in very handy. Are the fee's for one problem
    only or can that extend over a period of time for other problems solutions as well?
    Genius:
  • 1,913 Answers
Check your ram clean dust from it and slot.
then refix ram.
if problem remains.
u have to fix hdd bugs.
for that u must have bootable disk.
or xp disk.
then go to recovery console.
then type "chkdsk /r"
then it fix the problem
Posted on Nov 14, 2008
  • kishor khatri
    kishor khatri Nov 14, 2008
    pls rated this sol as fixya.
I cannot boot up laptop it says control alt delete then nothing
You need to try booting in Safe Mode with Networking and if that fails then Last known good configuration should work. Below are the steps to perform Last known good configuration howver Safe mode with networking is also an option under "windows Advanced option". Now if you succeed logging in to Safe mode with networking then try performing system restore by going to Start....All Programs....System Tools and System restore.
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: your PC will boot to the windows.
All the Best
Dec 27, 2010 | Samsung Computers & Internet
Dell D600 won't start up
There might be a problem with your memory or hard drive or even your OS I suggest replacing and testing with a different memory stick and/or Hard drive.
Mar 31, 2010 | Dell Latitude D600 Notebook
Will pass bios but then will not load windows, will not boot from CD, will not boot in safe mode. Tried reinstalling windows, will not, I can't start so can not use system restore. Will not boot using the...
step 1. open up the case and locate your hard drive
step 2. carefully remove the cables and power to the hard drive and remove it
step 3. goto your local office depot, staples, walmart or radio shack and buy a nice new hard drive somewhere around 250 gigs should be plenty for you,
step 4. now that yopu have a nice new hard drive put it in the spot where your old hard drive was in the conputer and plug both cables back into the new hard drive, after this is done put your case back on and start the computer up with your windows cd in the cd rom drive and reinstall windows. :) hope this helps
Oct 13, 2009 | Dell XPS M1530 Laptop
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
My desktop has msg: problem has been detected and windows has been shut down to prevent damage. Give steps to do but ultimately goes right back to this error. Can't rebook with CD, can't go to safe mode,...
As per your issue since you cannot boot to safe mode or last known good configuration.probably your Operating system file is corrupted.Tried to boot from OS xp media or vista and try to repair the operating system.Change the boot sequence to boot from cd in the bios.
Aug 20, 2009 | Computers & Internet
Dell latitude d600 screen goes black during boot
ok after you have booted in safe mode do a restore to a date just before the last day it worked properly and try that restore is found here
start/programs/accessories/system tools/system restore
hope this helps
Mar 15, 2009 | Dell Latitude D600 Notebook
It wont power on.With a diagnostic fail of 1000-0146
DST stands for Drive Self Test, bunnydawg is correct in the drive is failing
Mar 08, 2009 | Dell Latitude D600 Notebook
Dell latitude d600
Greetings AROD718,
This error message is telling you that your hard-drive is nearing OR has already failed.
I would contact a buddy or go somewhere local to get Data recovery ASAP or if that is not important to you start shopping for a new hard-drive.
Hard drives are not very expensive and are simple to install, if you need further assistance please reply back!
Good luck,
Shawn
Oct 31, 2008 | Dell Latitude D600 Notebook
Wont boot
for no boot issues, you can try accessing windows advanced boot options by hitting F8 as soon as you see the dell splash screen. try to boot to safe mode or last known good configuration. if it doesn't work, last resort is to reformat the computer.
i hope this info helps.
Sep 04, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
74 people viewed this question
Alun Cox
