Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Brown residue on crockery
Initially the machine (Hotpoint Aquarius dwf30) stopped taking in water, but that problem seems to have self solved & now machine works, but there is brown residue on crockery....
Thanking you,
  • pat6591 Nov 16, 2008
    sorry wiz, i don't understand your suggested solution, could you please expand ???
    Scholar:
  • 181 Answers
 If the rack is not overly rusted, a bottle of rack touch up is available and can be purchased at most appliance parts depots. Also new tine ends are also available to cover the rusting tips. The tine covers just push onto the tine tips...very easy repair!!
Posted on Nov 16, 2008
  • 2 more comments
  • fixyy Nov 16, 2008
    Q - I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
    A - New disposals have a "plug" in the connection stub for the dishwasher drain hose. This plug MUST be removed or the dishwasher will not be able to drain into the disposal.
    - My dishwasher is full of soap suds....help!!
    A - You may have used detergent not designed for automatic dishwashers. You may be using too much detergent/tablets. Or you may be using liquid detergent. Some rinse agents and mechanically softened water will also makes suds. Putting 2 tablespoons of oil into the sudsy water at the bottom of the dishwasher will help break up the suds. Sprinkle ordinary table salt liberally across the suds to disperse them. Add a large quantity of ice cubes from your freezer to the tub. This causes the water temp to lower, thus degrading some more of the suds. Try to drain the unit as much as possible, soaking up any residual water or suds with a dry towel. Let the unit fill again, and repeat the salt and ice if necessary.
    I also use a commercial spa or water bed de-foamer, which is found at Home Depot or any pool supply store. This works as a surfactant to break down the bubbles almost instantly. (Only squirt a few drops in and run the unit)
    Q - The dishwasher is empty when the cycle is over, but the next morning there is water inside the dishwasher, what could be wrong ??
    A - Two things to consider....clean water or dirty water?
    Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
    Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
    The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
    Genius:
  • 1,550 Answers
You can buy dishwash liquids, with water softeners.
A fast acting powerful dishwashing machine powder.
Prism effectively removes stains from crockery
Its also good too clean your dishwasher from time to time with DESCALER..
    Sergeant:
    Champion:
  • 200 Answers
HI
Make sure you do and that they are filled up.
thank you
Dishwasher inbuilt has recently stopped cleaning thoroughly. Little hard specks stuck on finished crockery, much worse on top shelf. top shelf items greasier and smeary... Cleans much better with Finish...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 26, 2011 | Dishwashers
My hotpoint aquarius dwf30 will not drain so will not wash...
Do you hear the motor run or is there deadly silence when you select drain.
Does the wash cycle start - do you hear water getting in and washer arms move?
Are there any lights flashing?
Jul 06, 2010 | Hotpoint 24 in. DWF32P Free-standing...
Where is the element on a Hotpoint Aquarius dwf30 dishwasher?
It sits in the base of the machine and you would need to remove the complete top section of the dishwasher to gain access to it, which involves removing the door first, then the balance weight and finaly the stainless steel top section
Mar 17, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hi i have a dwf30 for some reason all the items are coming out with lots of grease marks on them the tablet pops out ok as you can hear it but everything seems as if its not been rinsed out i thought it...
is there any strange rumbling or moaning coming from the drum ??? if so the oil and greace may be from the back bearing due to the bearing oil seal becoming faulty allowing water through to the bearings
Feb 08, 2010 | Hotpoint Aquarius WD640 Front Load...
Black on door seal and water filling fabric softner section in dr
hotpoint Aquarius
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 20, 2009 | Washing Machines
I have an initial fill problem with a Hotpoint Aquarius Washing M
You can attempt to reset the water level, but it sounds like that system is malfunctioning and going to require service.
Oct 29, 2009 | Washing Machines
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
May 18, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint Aquarius WD440: IT seem when it supposed to pump the dirty water out,the waters are not coming,but if i take the pump and put down on the floor ,the water are coming out and it run the whole spin...
If you are getting voltagae to the pump and the water is not pumping out then you have a bad pump, just replace it and you have the problem solved, If you do not have voltage then we would have to find out why.
May 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Feb 13, 2008 | Hotpoint WMA32 Front Load Washer
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
140 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
