No quality indicator
Have just been given 5400z however when connected sig strength 70% but quality zero, I currently use a 5410 on this connection with no problems 70% sig strength and 80% quality please advise your help greatly appreciated
thanking you
Terry R
  • 2 more comments
  • rileybill Nov 14, 2008
    Advice appreciated
  • rileybill Nov 16, 2008
    Hi Ginko, the aerial and cables are not the prob mate as I'm currently using the connection for Foxtel and a Humax IR-5410z sig strength 70% and quality 80%
    Terry R (rileybill)
    thanks for help will try tomorrow as gear packed away at the moment
    TR
  • rileybill Nov 17, 2008
    There is no problem with my dish or cables as it is being used at the moment and receiving a high quality picture,it appears that the Humax IRCI-5400z requires a C1 module to receive the Optus satellite which I suggest is what my problem is having a zero quality with this receiver, thanking you for efforts
    (that was a quick ten bucks)
    TR
    Genius:
  • 1,011 Answers
Sir,
Go up on the roof with a TV screen showing the strength meter, Pull the top
of the dish forward, does the signal increase or decrease. Now push the dish
backwards, what happens , pull the left side back, The right side back, is
there any increase in signal strength, If yes thats the way the dish needs
adjusting a fraction of a degree.
But if you really want a BETTER SIGNAL with no dropouts get a bigger dish.
Somewhere in the menu, there will be something about signal strength,
> some receivers show a coloured strip, one for quality [forget that
> one] and one for signal strength [thats the one you want, if it
> shows nothing , your not on satellite]
thanks
good luck
dont forget to rate the solution
Posted on Nov 16, 2008
    Scholar:
  • 181 Answers
From what I understand, no/low signal quality means you are not on the satellite you have selected.
Have you tried adjusting the motor on your pole to improve the quality?
I have found that you have to be 100% spot on with your alignment, even more so with motorised, as you are tracking an arc, and the slightest bit out and you have missed it.
Follow the guides and set up the dish on your reference satellite. Make sure you have an active transponder showing on the receiver if using this method ( Normally Thor 0.8w / 11.325 BBC World)
  • 3,037 Answers
Try to go to menu, installation,status, stb status, and you need to make a note of everything down and including to sys id, this will tell you of the stb firmware.
next
press ok
yellow
yellow so that you are in the left side, and (if you only get a small page exit out, then go to menu, select service, and choose advanced) scroll up or down and see what sats are there, if you only have hotbird then you need to load a new settings file, and you will need a null modem lead, get a store bought one, as if you can be patched then it has come to my attention that its best to have a full nullmodem for the bin.
in the settings zip there is a guide called how to for humbox, and you will need to find the program humbox4.1 this you can find using google
hope this gives you something to work with
  • 19,396 Answers
Check the satellite aerial orintation and the satellite cable.
  • Ginko
    Ginko Nov 16, 2008
    This usually happens when the cable or connector is bad or when the aerial dish orientation is slightly wrong.
    This can have been moved after you swapped from old receiver to new one.
    Do a channel scan again, and double check the orientation.
    If this still does not work, test the signal again using a different receiver.
    If your old sat box gets good quality check the null modem cable, eventually test a different Null Modem cable.
  • Ginko
    Ginko Nov 16, 2008
    If none of the above works, try setting the sat box to non-motorised , then set the dish at 1W and do a scan. If you use a null modem cable, try replacing the cable first.
Hello is there a way I can change the network setting on my LG phone LGL63blight now it's set to Lte and I can be next to my WIFI and I can only get 2 bars
The LTE indicates the phone network signal strength and not the Wifi signal strength. Go to your wifi setup and connect screen to see the Wifi signal strength.
You can try changing your connection to 4G and seeif you get a better connection in your area
Settings ->> Mobile Networks
Sep 26, 2017 | LG Cell Phones
Connect wireless
All drivers, if available, are on the acer web site for your acer laptop.
Jan 29, 2014 | Acer Aspire 5050-5410 Notebook
No input 2 signal
The connections bad.... try rewiring the one for signal 2 or if its making a good connection... look for a weak spot in wire... that helped me when i couldn't figure out wiring
Aug 28, 2012 | Cars & Trucks
Even Transponderds Zero
Typically that indicates a bad LNB or connection to the LNB. Try moving the line to one of the other three ports on the LNB and if that doesn't work then you will need to replace it
May 18, 2017 | Directv HR10-250 DTV Receiver
Humax 8000T not used for a while, now says ''no or bad signal'' and says no channels available when it searches.I tried resetting to default settings but still no joy. When I checked signal status it says...
sig strength 29 is too low to lock onto. Humax needs 50+ to lock ideally 65+
is the aerial ok? try the set on someone elses aerial. If no joy then its possible the tuner is duff...but thats virtually unheard of.
Oct 24, 2009 | Humax Televison & Video
You may hear .. .. . . .
you have to change your channel type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
thern check signal strength.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 23, 2009 | Yahoo Messenger
Router connections
If you have a laptop in home 2 that is able to connect with NO issues whatso ever I would almost think its a security issue... Do you use the same kind of encryption on both home 1 and 2? (ie WPA or WEP)
Dec 31, 2007 | Computers & Internet
Pocket PC wireless internet
It is just like setting up a network card on the pc, except you need to tell PPC that the device either connects to "Work" or "The Internet".
Sep 19, 2005 | Toshiba e400 Pocket PC
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
