Craftsman ZTS 7500 dies when engage blades or when engage transmission
Replaced PTO clutch and main drive belt~ now when start runs fine till pull on pto for mower or take out of park to drive and it dies like kill switch~
seat kill switch not the problem~but i do believe that a switch is the problem~think it may be the master switch for pto~ am looking for a wiring diagram for this mower now so can trace out before buying switchseat kill switch not the problem~but i do believe that a switch is the problem~think it may be the master switch for pto~ am looking for a wiring diagram for this mower now so can trace out before buying switch
I have a bad battery on this mower have to jump it~ can bad battery cause pto start problem causing it to kill the mower motor?I have a bad battery on this mower have to jump it~ can bad battery cause pto start problem causing it to kill the mower motor?
well fixed the problem~ it was the battery~ replaced it mower runs like a new one~ battery must have had a short in it~well fixed the problem~ it was the battery~ replaced it mower runs like a new one~ battery must have had a short in it~
found the problem~it was the battery~ had a short in it~ caused all the problems~found the problem~it was the battery~ had a short in it~ caused all the problems~
You can't post conmments that contain an email address.
Re: craftsman ZTS 7500 dies when engage blades or when...
Check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Belt-the number one cause for your blades not to engage is that your belt is either stretched or loose causing it to slip or fall off completely. Belt could have snapped also. When you are trying to process too much grass/leaves they could pack up under your deck and push off your belt.
The seat occupied switch energizes the operator presence relay. This relay allows power to the PTO clutch from the PTO switch only when energized (operator in seat).
A simple test
1.PTO switch OFF 2.Ignition switch to ON position. 3.Engine not runnjng 4.Operator in seat
Pull PTO switch. You should hear the the clutch engage with a notable pop. Then turn off PTO and it will make another pop or clunk when it disengages.
Similarly with PTO engaged, if you rise from the seat it should disengage.
Also a failed charging system may allow the engine to start and run but not provide enough current to properly engage the electric PTO clutch. With engine running check battery voltage is greater than 13VDC.
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
There is somthing in the PTO that is binding up. I am assuming the PTO is for the mower blades. The belt(s) could be binding up, not on the pulleys, etc. The blades should turn by hand easily.
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Cody,
Yes, I am sitting when I do engage the blades on my craftsman zts 7500. All you do is pull/push the engaged button to your left well you are seated.
