Question about Sony VAIO VGN-S460 Notebook
Overheating problem Hi, I got vaio vgn-s460 model and I've had overheating problems since I bought it. What can cause this problem? The fan outlet is uncovered all the time but it's doesn't influence. Is there any way to fix it? Thanks for help
  • muster918 Nov 14, 2008
    Thanks. I've tried few times with "block" it helps a little bit. I was thinking that there is a problem with fan or so. Anyway, thx!
  • 70 Answers
I'm not sure if there is much you can do about it, it's a design flaw. Keep vents clear, use it on a flat surface. If possible, put small blocks under the laptop to give it some extra airflow. You can get cooling stands like this:
But I'm not sure how effective they are.
Good luck :)
Posted on Nov 14, 2008
Overheating for sony vaio vgn-bx546b
Make sure that the laptop is on a hard surface. If it is on a bed or on your lap, it will get hot because the fans are being blocked up and the hot air can not escape. I hope I helped.
Apr 16, 2010 | Sony VAIO VGN-BX546B PC Notebook
Sony vaio fan is making a grinding noise, how can i fix this?
The sony VGN-S460 seems to have an inherent problem with their cpu fans. It is apparent that the fan uses a ball bearing system which over time becomes worn and causes the grinding sound.
The only solution is to replace the entire fan assembly as they are inseparable.
Nov 15, 2009 | Sony VAIO VGN-S460 Notebook
I have the same problem for Sony VGN-S460 heatsink fan problem
I trust that you have purchased the entire fan assembly as they are inseparable from the heatsink. You must disassemble the entire laptop in order to remove the fan assembly. they are two screws that are below the motherboard that must be remove in order for the fan assembly to come apart.
If you cannot achieve this yourself, or lack confidence in your ability to rebuild the unit after, you can send the unit to us at and we will accomplish the desired outcome. We have worked on this system resolving this very issue.
Oct 05, 2009 | Sony VAIO VGN-S460 Notebook
Sony vaio VGN-s460 when I power up, the vaio screen pops up , then nothing. Any help appreciated
if you recently installed a software or a component, that caused the issue. if removing it or a system restore while on safe mode did not work, please consult the link below for some laptop DIYs
Sep 13, 2009 | Sony VAIO VGN-S460 Notebook
Sony vgn-s460: screen blinks, fan runs very loud
Possible clock timing of CPU is wrong. Is it two fan on this laptop? Maybe one is not functioning. Plus check your power supply if gives correct power!.. If none of this , it comes to the MB and possible a CAPS making problem. Need expert.
Aug 06, 2009 | Sony VAIO VGN-S460 Notebook
Sony vaio VGN-SZ430n- overheating, always been a problem since purchase 2yrs ago. Now, fan has warped- this unit is a pain to get into, however I have- to attempt to replace fan with old laptops. Wondering...
Hi, I use the air cool product from that allows you to move the laptop constantly to prevent a hotspot on your desk. I think it may work for you.
Apr 09, 2009 | Sony VAIO VGN-SZ430N/B Notebook
I need steps to replace Fan for my Sony VAIO VGN-S460
the fan is screwed together with the motherboard, the only way i figured is to separate it is completely unscrew the motherboard, cd drives.....then unscrew the fan from the bottom side of the motherboard....
i took the fan out just today, wantted to add some lubricating oil to it, but then can't manage to separate the blades & expose the centre
how much did the replacement fan cost? i am in canada, not even sure sony stores here have it.
Dec 25, 2008 | Sony VAIO VGN-S460 Notebook
To my knowledge of my understanding i can see that your system all always heat up before working for a very few minutes and for that you have to check the Processors fan if it is rolling and if it is not then turn your system upside down and disaasembly the system and remove the fan that is not wor4king and replace with a new one and that give you your rest on your pc.
Sep 05, 2008 | Sony VAIO VGN-S460 Notebook
Noisy fan--sony vaio vgn-s460
then if that is the problem to your pc then turn your pc upside down and dissassemled the screw at the back then your keyboard should be lift up slightly and if you can not do that on your own try to contact someone in that field to help you but just for you to tell the person that you know what is wrong w2ith the pc the person should try and check if there is anything too close to the fan that the fan is touching and if there is nothing the fan is touching and the noise continue then change the fan with a new one. bye any question again.
Aug 25, 2008 | Sony VAIO VGN-S460 Notebook
check adapter output also may be problem with dc socket on laptop loose or somthing.
Apr 11, 2007 | Sony VAIO VGN-S460 Notebook
Sony VAIO VGN-S460 Notebook Logo
180 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
