Question about Acer AL1916W 19" LCD Monitor
Horizontal lines across my monitor.
My monitor was working fine for about 3+ months. Then I gotthese faint horizontal lines. Just turned on my screen one day and had horizontal linesthat span the width of the screen and scroll along with the image. It's like whatever image is on the monitor bleeds across the screen. Like at night when you see light spread horizontally from a streetlight. I hope this helps explain the problem. Any help would be awesome. Thanks.
SOURCE: acer x191w monitor background is moved to the right with about 2inches of black on left side.
I tried this and it still does not fix my problem. I went into Menu and hit reset by mistake and that totally screwed up my monitor. Now the left side gets cutoff and no matter what I change the resolution to it does not fix it.
Whjat should I do?
Posted on Apr 15, 2008
ginko
  • 19396 Answers
SOURCE: desktop is dispalyed horizontal on monitor
The Ctrl-alt direction key sequence is supposed to be used for changing your workspace. On my computer at work it changes the screen orientation Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees
(If that doesn’t work, try Ctrl-Shift-R)
Posted on May 31, 2008
SOURCE: monitor with horizontal shakes
i have found a twisted groundline makes my monitors horizon dance, try a more natural approach to your power cord setup, like a waterfall or growing vines, rigged every 8 inches
Posted on Jun 25, 2008
bammbammfran
  • 159 Answers
SOURCE: Acer AL2216WBD LCD Monitor Problem
If your computer does not have a video card that supports the correct resolutions for the widescreen monitors, then your picture may get stretched. Much like watching normal tv programs on a an hd set. It will eitther strech or cut off the picture.
Try different settings in you computer display settings.
Fran
Posted on Oct 11, 2008
  • 7 Answers
SOURCE: Rolling Horizontal Lines across the screen
ground loop is problem. Many answers available via Google.
Posted on Nov 25, 2009
Our three year ol Samsung TV has dark horizontal lines across the top of bottom of the screen. It is getting worse
Welcome to fixYa!
When you see lines like these across your LCD, it indicates a problem with your monitor's electrolytic capacitors.A faulty filter capacitor in the power supply board (SMPS board) can cause horizontal lines across your monitor screen.Horizontal screen lines are one of the most visible problems I see in LCD monitors & TV's that are 3-7 years old. It can happen as much from heat, humidity & less-than-ideal operating conditions, as it can from fluctuating current supply or manufacturing defects.
The way to repair horizontal screen lines is by removing the capacitors from the printed circuit board (PCB) and testing them with a LCR meter.
If it shows zero, there's your confirmation that the specific capacitor needs to be replaced.
now if you can replace them your welcome but i wont suggest that , cause you may break it more....!
any ways do comment if it helped you in any manner!
Apr 30, 2011 | Samsung HL-R6168W 61" HDTV
Flickering horizontal lines across monitor screen
Do you have the monitor plugged into a power strip. If so unplug it and plug it directly into the wall.
Nov 09, 2009 | ASUS PG221 22" TFT LCD Monitor
Geforce 3 analog output: I have horizontal, blurred/faint lines scrolling from bottom to top of display, spaced 6 inches apart.
what kind of monitor? Have you replaced the cable? Try the pc on another monitor. You need to see if it's actually the monitor or the video card. replace the broken or defective part.
May 30, 2009 | Nvidia 64MB GeForce3 AGP Video Card with...
JVC AV-K21TR
The faint white lines at the top of the screen is the warning that the pump-up capacitor in the vertical output circuit is going bad and the output itself is about to short out. When the TV stops working, the vertical output IC has finally shorted out. Replacing the vertical output IC, the pump-up capacitor and possibly a small value resistor next to the flyback (B+ for the v-out) should bring the set back to life.
Jan 26, 2008 | JVC AV-27230 27" TV
Horizontal lines
Horizontal blur can be caused by both a bad monitor or a bad video card/Card Slot on the motherboard.
The easiest way to check this is to connect the monitor to a known good system. If the problem follows the monitor to the good system, the monitor is bad and will need replacement. If it works fine on another system the problem is the video card/slot
Jan 04, 2008 | Dell E207WFP LCD Monitor
Horizontal line throught the screen.
Sounds like it might be getting too hot and/or going bad. Try it on another machine and see what it does. Also try another video card because the video card could be going bad.
Nov 12, 2007 | Gateway FPD1975W 19" LCD Monitor
Horizontal line across the middle of the screen
replace the vertical ic,when your vertical ic is defective you can see the horizontal line across your screen
Oct 19, 2007 | Gateway FPD2275W LCD Monitor
Faint horizontal lines in picture
This is usually caused by a problem in the Horizontal Output section, around the Horizontal Output transformer usually a capacitor or diode going or gone faulty... the line you see are the Horizontal "Retrace" lines that are useually "Hidden" when the circuit is OK..
Jul 30, 2007 | JVC AV-27320 27" TV
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
56 V - faint horizontal lines across the display
u can search problem in vertical section may be sum IC component was dry resold them .
Aug 02, 2006 | SAMTRON 55V 15" CRT Monitor
Acer AL1916W 19" LCD Monitor Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
