Konica Minolta Magicolor 2450 Printer Logo
Posted on Apr 17, 2012
Noise from magicolor 2450
Printer is making a loud, rattling/vibration noise, was a message recently about OPC drum being low - could this be the problem?
5 Related Answers
Anonymous
  • 202 Answers
  • Posted on Mar 06, 2007
SOURCE: Printer makes extremely loud clicking noise
http://printer.konicaminolta.com/support/current_printers/mc2430dl_sup.htm#Printer_Specific_Documentation The user guide should be helpful to you to pinpoint what is causing the noise. Sounds like the belt drive or gears may be having a problem. Let me know what happens. Tim
Anonymous
  • 214 Answers
  • Posted on Sep 17, 2008
SOURCE: Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
A
Anonymous
  • Posted on Oct 23, 2008
SOURCE: Drum Cartridge Warning won't go away
Replace the fuse on the bottom of the drum cartridge.
Dan Hudson
  • 119 Answers
  • Posted on Oct 30, 2008
SOURCE: OPC Drum Error
Replacing the fuse is only half the job. You also need to empty all the spent toner out of the drum as well. I actually drilled a 1/4 inch hole, poured out all the purple toner, and covered the hole with an old 5 1/4 floppy write protect tab. Any good piece of heat resistant tape should do. Then replace the fuse. Make sure that the contacts the fuse rests on are clean as well.
Anonymous
  • 192 Answers
  • Posted on May 20, 2009
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Konica Minolta Printer 2450 'Service call 14'
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support.
https://www.konicaminolta.com/?_ga=2.925553.1712686740.1643574641-1075806822.1643574641
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Toner problems with Konica Minolta 2450
very annoying message i agree - most likely caused by toner dust.
The printer uses a carousel to rotate the toner cartridges. Dust and toner can easily spill as the cartridges rotate. The error can appear at any time but seems to be most annoying after a paper jam or other error. It is also important to make sure that the cartridges themselves are clear of toner dust. Pay particulair attention to any copper contacts on the cartridge.
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
I have magicolor 2300 DL.I just replaced Cyan
make sure your cartridge is not stuck and pushed in all the way in printer. If it gets struck it will dump ink out and waste it.
Have a Magicolor 2430 DL. Getting message "drum low". Does this mean I have to replace the imaging drum or something else?
Most all replaceable parts on MagiColor printers are literally scheduled to be replaced after a certain number of pages printed using them. Officially, this is to ensure print quality remains sufficient. Unofficially, it's just another way to **** money from your wallet.
That being said, there is likely a fuse somewhere on the OPC drum unit that, when replaced, will reset the page count for that unit. Once the page count is reset, the fuse is blown, and counting resumes.
Examine the unit for large, silver, metal contacts. The fuse will be underneath those (or very nearby). Either replace the fuse or temporarily short the contacts. If you short the contacts, turn the printer on, verify the printer "thinks" the drum unit has been replaced, turn back off, and remove the short circuit.
1helpful
2answers
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
1helpful
2helpful
OPC Drum
OPC is organic photo conductor. Not sure what that means but apparently we need it to be able to print stuff. Yours has run out and you need to buy a new one. Should be about £100 apparently. But I'm having trouble finding anywhere that sells them, most people just seem to sell toner cartridges. The part number is 1710591-001 if that helps. Unfortunately I haven't worked out how to fit it either. Sorry. Good luck! (I hate this printer...)
2 multi color lines loud vibration noise
If you have changed the OPC drum and cleaned the entire insides of the printer after taking out the toner cartidges and OPC drum.You need a tech to look at it. The fuser is probably messed up from loose toner.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
