Question about RCA HD52W59 HDTV Projection Television
Convergence problem with my RCA R52WH73
My tv is bowed at top and bottom and the colors are out of alignment. I don't have a convergence option in my menu. I would like to fix it myself but I have no idea what to do. If it requires a new part I do not know how to soder. If I have to go to a shop how much should it cost to fix. I don't want to get ripped off.
  • florentinojv Nov 14, 2008
    I have the same problem. I know how to solder. Can you tell me where is isthe IC that i have to solder? Thanks
  • 346 Answers
`soldering is easy.put the solder wire to each pin of the ic ,one at a time. heat the soldering iron
bring the iron to touch the solder. remove the solder and then the iron .this should take 3seconds for each.make sure that sotder does not fall between each pin and that solder does not fall anywhere on the circuitr board
Posted on Nov 18, 2008
  • 4,234 Answers
Unfortunately, you will need to be able to solder in order to fix this. It can be as simple as resoldering the pins on the convergence ICs. If you know someone that can help with soldering, update this and I'll provide additional instructions.
Posted on Nov 14, 2008
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Good day!!!I i had problems with the fl 231 fuse on my RCA D52W23
FL231. FUSE.... The RCA ITC222 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and green shadows? Does it have bowing in affect on the top and bottom of picture? when you turn it on does some thin red green and blue line bow in from the top then go away. The main question to determine if you have the fl231 fuse problem is if you go into customer menu then setup do you have the "CONVERGENCE' option. If you do not. then i suspect you have this problem. In the manufactering of these sets Lead free solder is used. now there is great debate over the use of lead free. connection tend to be more brittle. cracks develop around the solder connections of the high voltage flyback transformer. this very small crack set up oscillations in the cuicit with a 400 milliamp fuse. THis fuse cant take it. When this fuse blows the processor then does not know its a projection tv with three projection tubes. it thinks its a crt tube tv. and crt tube tv dont need "convergence" so it removes the convergence from the set.
TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics.
2. Remove the back. there a number of torx 20 screws.
3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse.
4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes.
5 when you get the tray up the bottom side of the board can be accessed
you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace
7 RESOLDER FLYBACK CONNECTIONS simply heat up and add a little solder
8 reassemble set. make sure you examine the set for loose connections.
9 and remember "BE Careful'
on Jan 14, 2009 | RCA R52WH73 Projection Television
It seems the picture has gone bad on our our RCA 52" Model No. R52WH73 projection television. It is only 3 years old. The picture is bowed in at the top and bottom and the color is off. Will it be cost...
Your convergence ICs or convergence board is bad. More than likely it is the convergence ICs. About a $100 fix from a reputable repair shop. Hope this helps. If you need more info let me know.
Jan 25, 2010 | RCA R52WH73 Projection Television
The colors on the tv are out of alignment
How bad? IS the picture bowed in on top and bottom? this is a indication of convergence problem withhout knowing anthing else i suggest reading the "fl231 problem in tips and trick section of this website that might be a start
Dec 10, 2009 | RCA R52WH73 Projection Television
Same problem as above, picture bowed top and bottom, convergence
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix using this link on Fixya
Jul 19, 2009 | RCA P52939 52" Rear Projection Television
Bow tie looking picture with 3d color mis-alignment
you have lost convergence. First thing to check is to see if you are missing the convergence option in the customer setup menu. if you do not have this option then i suggest reading the article in the tips and tricks section entiltled "the fl231 fuse problem" this is a common and sometime easy repair if you do have it then you might need a convergence power board
Mar 09, 2009 | RCA R52WH73 Projection Television
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
Autoconvergence option is GONE!
You will need to replace the ITC222 convergence power supply board and the FL231 fuse on the deflection board. You can get replacement parts at the following link with free installation instructions.
Sep 24, 2008 | RCA R52WH73 Projection Television
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
47 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
