Question about Nokia 5310 Cellular Phone
NOKIA 5310 can't turn on
I have nokia 5310 mobile which only switches on by charging and do u have have any alternate way to switch on my phone
  • 9 more comments
  • drepiedre Nov 15, 2008
    my phone is only a couple of weeks old, and it wont even turn on! ive been charging it for 24 hours and it wont even turn on with the charger plugged in to it....it seems to be charging...but the buttons wont work.
  • Daniel619 Nov 15, 2008
    i plug in my phone nokia 5310 phone to the computer and i was putting music in too it.. then i put it out and it jsut turn off, and when i turn it back on it showed the nokia logo and the hand thingy then flash and just goes black again and no matter what i try, it just wont work
    need help fast!!
  • paulb1064 Nov 22, 2008
    It worked fine, then one day just stopped. Ive tried everything, i.e. take out battery the sim & replace, with the charger & without. All that it does when turned on is show the "hand shake" then tries to show the date/time screen, the screen goes dim then bright a few times, then turns off altogether. Ive taken the phone to bits there are very few parts that look like they can go wrong. Im at a complete loss as to how a modern £100 phone can just stop. Please help with any possible solutions. Thanks in advance for any help. Paul
  • seanymuppet Dec 03, 2008
    exactly the same turns on get to date time goes off cant reset it wont go on stadby and cant connect to computer to install new software how can it be fixed anyone???
  • Anonymous Dec 23, 2008
    great fone and all but it just died on me...
    this happened before, i handed the fone back into the shop i got it from and they packed up and left shop :S wasnt too happy with it. The best thing is to take it to a technician if it is still under warranty.
  • Bilang28 Jan 06, 2009
    When i manage to get the power-button to work and turns it on the screen start as grey. Nothing happends, but makes sound when I press the center button. I know the screen works becouse one ore two times it has worked fine.
    This is badly weird!
  • suzannbp Jan 12, 2009
    My daughter's phone worked just fine for two days and then she turned it off. Only to find she could not turn it back on again. When she does she gets the hand shake start up screen and then the screen turns white and then black- then it just turns off. If anyone has any solutions please let us know. We can not take it to the dealer since we bought it off the net from unknown.
  • Anonymous Jan 14, 2009
    I have downloaded songs to my memory card about 1,9 GB and as soon as the mobile was disconnected from the PC it turned off and does not turn on. I still try to resolve this.
  • Matty 5310 Jan 20, 2009
    hi
    ive had my nokia 5310 for a couple of months and it has been a great phone no problems at all but then yesterday i was on the train with some friends and we were exchanging music via blutooth when my phone turned itself off i thought that the battery had ran out since it was on low and i was sending and recieving music.
    however when i got home i put it on charge and then today i tried turning it on and i get the opening nokia handshake screen and a beep the screen goes white and the black however i occassanily get the time and date settings briefly before the screen goes black...
    please help me since it has been an excellent phone up till this problem.
    thanks, Matt
  • Anonymous Jan 23, 2009
    my phone turn off after its batery was finished and then i went for recharging and then a white and black screen appear but then it turn off its self coz of nt enuf power to turn on so i waited n waited to let d battery to charge longer and after that my phone wasn able to turn on anymore...lol
  • Anonymous Mar 25, 2009
    when i turn my one on the screen just stays black but you can hear everything including the handshake, i did everything, i just go ti so it didnt come with a sd card or anything someone plz help
Ok guys i found the solution
i just took everything out of my phone.. like all the memory cared and sin and battery
*your phone should be off*
1) take every thing out
2)put in sim first then the battery
3)turn your phone on
*if it works then go to step 4 if it dont then sorry, i guess we didnt have the same prob.*
4) put your memory card back in and it should work.. i did it like three time so yeah
hope it helps, if it dont please dont blame me i was just trying to help and my phone is fix now =DDD
Posted on Nov 15, 2008
Okay, so I totally freaked when this happened to me :(
BUT! I think I figured out how to fix it :)
As mentioned by others, remove the parts and put them back in.
1. Remove the Battery
2. Remove the Sim Card (You can't remove without the battery first taken out [SO DON'T TRY :P])
3. Remove the SD Memory Card
Now... I put them all back in and powered it back up... and it did the white/black screens :(
So then I tried again, several times, to no avail.
What worked for me is, when putting them back in, ***do not insert the SD Memory Card***
Power it up with just the battery and Sim Card, and see if it works. For me it did. I think something in the memory was corrupted... :(
I've since tried powering the phone off, putting the SD Card back in, and turning it on... it still loads now, but it isn't registering the memory :(
So, as a lesson, back up your data early and often. Which I luckily did :) And now I think I have an excuse to upgrade to a bit larger memory :P
Hope this helps!!!
~OkamiShonen
Posted on Feb 01, 2009
Ok this is what I did..
I went crazy on my phone and changed random ****..turned it off..took every thing out..followed the same steps as Daniel but it didn't work for **** (no offense), but if you want help, feel free to email me at jenntherandom@yahoo.com :P
Posted on Dec 03, 2008
2 Suggested Answers
  • 298 Answers
SOURCE: NOKIA 5310 can't turn on
Did you replace battery recently? Sounds like it has bad or wrong battery. If not, it is just dead.
To fix:
Power up phone on charger
While it is ON, pull the battery
Leave out for 1/2 to 3hr - phone still plugged in
Replace Battery, phone will power cycle and start charging
Leave plugged into charger 10-14hrs
Should be good now
Posted on Mar 26, 2009
Restriction code
Hi. You can get the accurate restriction code for your Nokia 5310 from
ProUnlocking.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia 5310 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5310.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5310 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5310 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
Jul 26, 2014 | Nokia 5310 Cellular Phone
My nokia 5310 won't open. only the charging battery sign appears when I plug the charger. then it goes off when i unplug the charger. what shall i do?
Dear Nicole
It seems that there is a problem with with your mobiles ON/OFF Switch.
to resolve this
1 remove the battery
2 carefully remove the camera cover
3 now you will see that there is a push kind of thing under the on off button
4 remove the white color plastic sticker on the button and take a metal pin or something equivalent
5 insert the battery
6 now short the on/off button for approx 3 seconds
your mobile will turn on
thanks
Gagan Gupta
Is that Useful?
Mar 17, 2011 | Nokia 5310 Cellular Phone
I cannot get my phone to unlock.
Hi you can unlock your Nokia 5310 mobile phone using the unlock code. you can get the unlock code from this site http://www.wickedunlock.com/ at reliable cost...
Do not enter any wrong unlock codes on your Nokia 5310 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5310 mobile phone, your phone may get hard locked and sometimes become unusable.1 - Switch on your Nokia 5310 without any sim card.
Jun 14, 2010 | Nokia 5310 Cellular Phone
Freezes up and switches off
HI there its a problem of your mobile software. Please reinstall the nokia phone software from NOKIA website and use it. Then your problem will solve 100%. Thanks.
Mar 10, 2010 | Nokia 5310 Cellular Phone
I need to unlock my Nokia 5310
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” in your area.
You can also try this WEB site.
www.unlock-free.com/nokia-master
Dec 30, 2009 | LG KU990 Viewty
Unlock code for nokia 5310
http://www.unlocking4u.com/nokia-5310/rs6wp9/ will give you the unlock instructions for your nokia mobile.
Nokia 5310 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia 5310 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5310 mobile phone, your phone may get hard locked and sometimes become unusable.
Note :For Nokia 5310 mobile phones locked to the network Fido in Canada follow these instructions :
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5310
Each Nokia 5310 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 5310 mobile phone using the form above.
Dec 27, 2009 | Nokia 5310 Cellular Phone
I need an unlock code for nokia 353657011043528 please
Hi michael_rodg,
http://www.mobileunlocksolutions.com/ will provide you with an unlock code for your Nokia 5310 mobile. The instructions are as follows:
Oct 19, 2009 | Nokia 5310 Cellular Phone
Basically my cell phone won't switch on
This is an old problem of Nokia 5310, sometimes, this phone will just automatically switch off. Please try this one:
1. Remove the battery of the phone and leave it for about 2 minutes.
2. Insert the battery and try to turn the phone on.
3. If you will get the same problem, you need to bring it to the authorized Nokia Care Center for firmware upgrade or repair.
NOTE: If the phone is under warranty, it should be free of charge.
Apr 11, 2009 | Nokia 5310 Cellular Phone
To fix:
Should be good now
Mar 26, 2009 | Nokia 6500 Slide Cellular Phone
Nokia 5310 Cellular Phone Logo
2,282 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
