Question about Poulan 12a Elec Blower/Vacuum
Gas cap swells
When I first use the leaf blower, the gas cap goes on easy. If I need to refill the tank, I find that the gas cap has swelled so that I cannot insert it. I have to wait at least 12 hours before the cap will dry up and fit back in its receptacle. So far I have used three of these caps with the same result. Evidently there is a material problrm here. This is on a leaf blower.
family: 5PWE8,0264BY
model: P8V200 711847
S/N: 06238n102378-1
  • 398 Answers
Yea its not gettin genough air thru with the gas. make sure your whole airfilter area is cleeean. or if the cap doesnt have small holes in it you should drill small holes two about .5 inch apart, with your smallest drill bit.a little bigger then pinholes, just enough so you can see there is a hole there. trust me iv done this before.
Posted on Mar 20, 2009
My blower seems to not want to go to ful throttle
This happened on my older Ryobi as well. Turns out it was the fuel lines. The ethnol in the gas made the lines swell up inside.
Oct 20, 2014 | Ryobi Blower Vac 205mph Leaf Blower Or...
I cant get it to start. The primer bulb wont refill with gas
The bulb pulls fuel from the carb into the bulb and back to the tank, if the bulb does not fill it is because there is a fuel blockage, either in the fuel filter in the tank, or the screen in the carb itself.
Jun 03, 2012 | Echo 135 mph 390 CFM Gas Blower PB-250C
Service engine soon light came on, replaced gas cap it went off but a week later it came back on, when it try to fuel the truck it spill the gas back out like it is a full tank
One of the most common causes, is blockage in the venting system from fuel entering the vent lines and into the charcoal canister, the fuel gets absorbed by the charcoal canister causing it to swell and block vent lines. the gas tank contains both fuel and air. when you fill it up the gas displaces the air and the air has to go somewhere. but the air that is displaced is full of gas vapor so the gas vapor goes to the vent lines and into the charcoal canister, when the charcoal canister swells up it prevents the air from escaping the tank, canister could be clogged,canister filter may need replacement,electrical connection to the close valve may be open,canisterf might be damaged,purge valve from canister might be clogged,vent hoses might be clogged, the vent hose could be clogged, or the vent hose may have a kink. all this is caused by overfilling the gas tank, getting that last drop of gas in the neck of the fill tube.
good luck!
Aug 11, 2011 | 2005 Nissan Titan
Primer bulb on Yardboss blower will not **** fuel from tank. Blower will run if primed manually.
remove your carb and clean it and replace diaphram's and needle , they tend to swell up from ethanol that is used in the gas now a days, and the diaphrams turn stiff and won't pump fuel. then put fresh gas in when you are done and also replace fuel lines and filter too., probably primer to because once it is hit with carb clean it just crumbles, good luck
Jul 31, 2011 | Homelite Consumer Products MightyLite...
Darned gas cap will NOT go back on ~?
Check the threads on the cap and the tank, they may have been damaged. If so, it may require a new gas tank, or a new cap.
Mar 24, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Reluctant gas cap
It is a problem the plastic swells and gets trapped under the lip of the tank. There is a later cap that will fit that has a metal part instead of plastic
Jan 18, 2010 | 2001 Moto Guzzi California 1100 E.V.
Why is the gas cap very hard to remove and put on?
Are you storing it with fuel in the tank? You don't provide a model number. I suspect she is a little long of tooth. The vented fuel cap didn't have to deal with the ethanol added to most fuels today. My Pioneer fuel cap swelled when I put her away wet, now I grunt a little removing it. A new fuel cap may only solve this problem for a short while. Isn't ethanol wonderful? Fuel line replacement is next. HTH
Lou
Nov 19, 2009 | Poulan Garden
Craftman leaf blower when I press primer bulb I get air in line. It seems to be coming from block that choke is attached to hoses look good.
Diaphram gasket in carb is swelled and air is getting through,get a carb reduild kit and it should be fine.
Aug 05, 2009 | Craftsman Blower Attachment
Just bought a used leaf blower, homelite, gas leaks out of the gas tank, where the gas tube fits into it.
"top of the gas tank where the gas tube fits into the tank"
I assume you're describing the gas tank cap. if so, the o-ring is missing from the gas tank cap. You can find those at hardware stores.
May 29, 2009 | Homelite 'Yard Broom' Leaf Blower
Poulan 12a Elec Blower/Vacuum Logo
75 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
