Question about SanDisk Sansa e250 MP3 Player
Reset data base stuck problem
Hi sir i have sandisk e250 2gb ipod. i face the problem from last 2 months that is still on reset database it is on stuck . it is not enter into the menu. what can i do sir,no one can not repaired this product in India. i got headache when ever i saw this,please send a solution to me . as early as possibly.
  • 8,596 Answers
Reformat the player if possible
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
Problem with Data storage devices
check the usb ports or drivers if those are your connecting port and get the right drivers from the MOB manufacturer
Dec 01, 2009 | Intel Computers & Internet
Sansa Sandisk stuck on "Refresh Database" screen. It will not reset.
1. Hold down the Power/Reset button for about 15 seconds to perform a normal reset.
2. Let the battery drain all the way so it will power off. If that doesn't work, then try to flash the firmware that's available from Sansa's website.
Oct 09, 2009 | SanDisk Sansa e260 MP3 Player
Refreshing database
User guide for Sansa e200R:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Check this link for Sansa e200 "freezing in refreshing database",
2 steps to follow up:
http://kb.sandisk.com/app/answers/detail/a_id/34/kw/e200r%20freeze/r_id/101834
1. Reset the device as described on the site of Sandisk.
http://kb.sandisk.com/app/answers/detail/a_id/189
If resetting didn't solve your problem
2. Update the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/306
2.1 Use the Sansa Firmware Updater for a download of your device
with the next link:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
2.2 Follow the instructions "update the firmware" for sansa e200 series:
http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200r%20freeze/r_id/101834
Sep 20, 2009 | SanDisk Sansa e250 MP3 Player
Remove error 0*80040e09 cannot update
When putting files up on your hosted site (or on your own server), make sure the file and the directory have the proper writes to Read/Write/Create. A special file called the .LDB file must be created and if it can't a ReadOnly status could be issued. It's a file that contains the names of the users currently accessing the MDB file. It stands for Lock Database.
If you are running on Windows add these attributes, if it's linux (not sure why you'd use MDB on a LINUX box, but it would be chmod +777.
Mar 04, 2009 | Microsoft Office Standard for PC
Sansa E200R gets stuck in refresh when I turn it on
http://www.sansa.com/support/sansa_e200/faqs
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
If that does not fix it, please post a comment with an update to your problem.
Jan 05, 2009 | SanDisk Sansa e250 MP3 Player
My ipod is facing with Rebuilding library
When you dried it off with a drier did you have the unit completely appart at the time? It sounds like you might not have dried off all the water. If you don't get all the water out it will stay there for a long time causing problems, and after that you'll end up with corrosion at which point the unit becomes virtually garbage. Also, one other thing to remember is the danger of too much heat. If you applied too much heat with the drier it could have damaged the electronics. At this point I would take the unit appart and blow it out with some pressurised air, then stick a new battery in and do a hardware reset if it allows for it in the software menu. It might even have a tiny reset hole on the outside.
Aug 28, 2008 | Creative Labs ZEN V Plus MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Hi...........
Well there is more than one or two answers 4 that.
you should first check if you are at simple recovery mode. If not (now this will sound strange) right click the database, click tasks/backup and make a LOG backup.
Now right click databases and click Restore Database.
You should choose a new database name (for restore practice) .
You will probably have your last backups at the bottom of the screen...if not click add and choose you latest data backup.
click the log backup and the data backup should be checked , too. on options tab make sure the database is left ready to use.
Oct 16, 2007 | Microsoft SQL Server Standard Edition for...
Ipod problem - playing songs in order
sounds like you need a new hard drive, which has a little read-write disk in it that is getting finicky... just to get more use out of it lay it on side or other positions and hear if works ok...if so its diffently Hard drive. you know the sandisks are 2 gigs no moving parts why doesnt somebody put 20 together making 40 gigs and replace the failing Ipods!!??? just pure electronics and no moving parts and much smaller...not like a hard drive. I thought of this over 30 years ago looking at the first plug in video game.
Aug 31, 2007 | Apple iPod shuffle MP3 Player
Refreshing Database
I love you!! thanks this helped me :)
Jan 28, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
