Question about Brother DCP-110C All-In-One InkJet Printer
New yellow ink cartridge not being recognized
I replaced my yellow ink cartridge with a new one. The machine is not recognizing that I replaced it. I also have tried the ink function to check the quality, and color. It says the yellow is low and will not allow an adjustment. All of my copies are coming out incorrect in color.
  • 85 Answers
Check to see if you removed the tape and that its seated all the way down
Posted on Nov 14, 2008
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Tip
How to replace a brother catridge.
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the cartridges is empty or near empty, the printer will tell you to replace that ink cartridge.
You can buy the cartridges individually, or you can buy a pack of all three color cartridges or a pack of two black cartridges. To replace one of the ink cartridges, follow the steps below.
All four of the cartridges are located on the right front side of the printer, behind a gray plastic cover. Pull the cover forward from the side, where there is a slight cutout for your finger to grab. When the cover falls forward, you'll see the four ink cartridge holders, coded by color.
For the ink cartridge that you need to replace, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop out toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right, they go black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once the cartridge is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place.
If you are replacing more than one color, repeat this procedure for each cartridge. Then, when you are finished, close the ink cartridge cover.
If you were out of ink or low on ink, the machine should recognize the new cartridge and perform the calibration process. If it doesn't automatically recognize the new cartridge, it will ask if you have changed one or more of the cartridges. Press "1" for Yes when it asks about a color that you replaced, or "2" for No if it asks about a color you didn't replace.
Once the printer comes back up to the ready state, print a color test page to verify that everything is working. If the test page comes out okay, the new cartridge is fine and you can either discard the old cartridge in the trash or save it to recycle. (But don't get rid of it before you are sure that the new cartridge is recognized and working correctly.)
on Jul 21, 2010 | Office Equipment & Supplies
Tip
How to change an ink cartridge on the Brother MFC-240C
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
on Jun 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brothers MFC885cw can't recognize new cartridge
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 08, 2010 | Brother Multi-Function Center MFC-240C...
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
Display says I am out of yellow,
Hi, since you've already replace the yellow ink cartridge for several times and its not recognize. Your printer might have a defective printhead. You may take your printer to the nearest HP service center in your area so that they can look on your printer further.
---->> Tirzo
Jun 04, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
New printer will not recognize the black ink cartridge
Some of the new machine includes only demo cartridges that is not full contain of ink on it. try to buy new cartridge and see what happen...
Oct 22, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Ink Cartridge Error PIXMA MP830.
pleaz clean the cartridge sensor and also align cartridges by program in your manual
Sep 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Won't recognize new cartridge
see here: http://www.fixya.com/support/t192382-near_empty_yellow
Sep 03, 2007 | Brother MFC-5440CN All-In-One InkJet...
Brother DCP-110C All-In-One InkJet Printer Logo
307 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
