Deefekt with the Monitor AOC 7klr
When I start PC, on the Monitor (AOC 7klr) can see only horizontal thin line very intensiv luminous. The line is about 2 to 3 mm tin and is in the centre of the screen(horizontal direction)..Whitch part of the curcuits of this Monitor can be faulty?..Or whitch tranzistor or IC??..Can be the feilure in Vertical deflection circuits?
Thank You for the answer...mit greetings: Vladislav Turon,Czech Republic
  • 153 Answers
The flyback transformer is normally at the Horizontal section of the monitor's mother board, It sounds that your flyback transformer might be the cause, bright intensive white lines can be fly back defective. . Try changing your flyback cause I encounter a problem similar to this and it works.
Posted on Nov 18, 2008
Which components need to be replaced when horizontal lines appear?
What horizontal lines do you mean? I can think of several.
- You could have a line of dead pixels on your monitor, this would probably be caused by wear and tear of the monitor, or because it has been handled the wrong way.
- You could be experiencing 'screen tearing'. This is caused by your videocard struggling for a moment.
- If you're running an older, analog monitor, it could be because the cable you're using is getting older and needs to be replaced.
Mar 05, 2016 | AOC CT720G 17" CRT Monitor
Thin horizontal black line on lcd monitor
It sounds like the light has gone out at that point on the screen, you're going to have to replace the LCD monitor itself.
Feb 23, 2013 | Motorola Mobility XT530 Fire XT Black...
Horizontal line across screen, only when dragging over large areas with the cursor
Have you tried updating DirectX?
You can also try scanning your computer with RadarSync (for free) to see which drivers are outdated. You can then install the updates by searching for them using Google. But, if you want to let RadarSync update them automatically then you can buy the license.
David
Feb 21, 2013 | AOC Computers & Internet
Window stay on and says lumines or brightness the
Try adjusting your brightness from the controls in front of the monitor.
Terry
Oct 01, 2010 | AOC 4 Vn 14" CRT Monitor
My AOC 5en CRT monitor have a horizontal line whole screen... how i fixed it?
this is called hline problem. only a thin line is seen in the screen and the screen is black. the cabinet needs to be opened then it needs slight setting from the picture tube to get the whole picture.
Sep 05, 2009 | AOC CT720G 17" CRT Monitor
White horizontal line across screen
Upgrade the refresh rate to 100 Hz and downgrade resolution
Jun 23, 2009 | AOC CT720G 17" CRT Monitor
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
AOC 53N PROBLEM
DO YOU KNOW HOW TO SOLDER. IF SO, TRY TO OPEN THE MONITR AND LOCATE THE VERTICAL SECTION AND YOU WILL FIND LOOSE SOLDERS. A SINGLE HORIZONTAL LINE MEANS THAT THERE IS A PROBLEM WITH THE VERTICAL LINEARITY OF YOUR MONITOR. FIND SOMEONE WHO KNOWS HOW TO FIX COLD SOLDERS
Aug 06, 2008 | AOC 5 En 15" CRT Monitor
Computers & Internet Logo
549 people viewed this question
David Payne
David Payne
