Question about SVA-USA HD4208TIII-VR 42 in. Plasma Television
Sva 3001 30'' lcd green light flashing continuosly
I have a 30" sva tv and when switched on the red light comes on to show standbye, when a channel button is pressed the light changes to green and for a fraction of a second the tv comes on with a box in the centre of the screen which says dtv then goes off, the green light then flashes without a break until the tv is put back on standbye and this is all i get from the tv, please could you help. thank you in advance.
5 Suggested Answers
snakehead
  • 1070 Answers
SOURCE: SVA plasma tv-model# HD4208T
you can get a manual for your tv at wwww.partstore.com that will guide through the setting up of your tv,good luck.
Posted on Mar 23, 2007
SOURCE: will not turn on
I check the power supply and that's ok, where can i purchase the logic board
Posted on Apr 10, 2007
SOURCE: SVA HD4208 42INCH Plasma will not turn on.
I called the factory or the distributor or wholesaler (customer service) that comes out on the web and they told to just buy a new remote cuz tv just isn't recognizing the remote. Can this be true? If this is far from being true, where do I buy the boards and what are the chances that the boards are the real problem?
thanks once again.
Trunking.
Posted on Feb 12, 2008
  • 9 Answers
SOURCE: SVA POWER SUPPLY
Wehave identified a common problems with theses sets manufactured by,SVA, Gateway, Viewsonic, Sampo and a few other brands. They all have aSamsung power supply board (LJ44-00025A), which has cause these unitsto lose power. There is a easy fix, replace the power board. But youask why should we? That's the right question. If these boards all havethe ability to fail with various parts and within various displays.This has to be a defective part. As of now, there is no recall on thispart. Therefore, we are generating a list of customers, who own thesedisplays and are requesting a refund for previously purchased parts ora replacement part at no cost to the customer. We are in the prelimary stages, so please be patient with our efforts.
Ifhave indentified your unit is salvage by an power issue an wish topurchase the indentified part (LJ44-00025A, we recommend you purchasefrom http://www.adc-ast.com/.
We cannot guarantee that any monies will be refunded by this claim.
Thanks
Shawn Moffett
Samsung Claims Administrator
If you are interested in participating in this claim, please email the requested below to samsung.lj4400025a@yahoo.com
<NAME>
<ADDRESS>
<PHONE>
<EMAIL>
<MODEL>
Posted on Apr 06, 2009
cheezungritz
  • 14 Answers
SOURCE: SVA PLASMA TV
I fixed Mine ($30 pdp on ebay lol) 4 $8 bucks it turned out to be a bad smd diode(1Amp) and a shorted scr (I replaced with nte5406) by the red error led I'd suggest to look 4 shorted diodes not ones by transformers but the more isolated circuits. also a few bad samwha caps that read high voltage potential (hypot) between gnd and the body of the capacitor (although not uncommon but I replaced them it Just in case) shock hazard. IMO its is a poorly designed power supply that needs some retrace jumpers to correct some of the flaws and even afterwords still some bias noise in picture but its expected in such an old tv.
Posted on Jan 27, 2010
When tv is switched on the red LED light flashes continuosly and tv does not come on?
There are three type of tvs, CRT type, LCD and plasma, so without model and brand of your tv, it is very hard to guess what kind of tv it is and what are possible causes of problem.
Let me know model and brand of your tv to provide you helpful info about its problem.
Thanks.
May 18, 2010 | Televison & Video
My 20 lg powers up, red light turns green, but no picture comes up, the channel id shows then it goes dark. I can wait up to ten minutes still no picture unless I change the channel a few times then it...
You wont want to hear this.....
Green dots on a LCD screen are burnt out pixels and unfortunately are incurable other than having the TV serviced at a high price. One of the reasons it is a good idea to get a warranty on these types of TVs is primarily due to this very problem....burnt out pixels.
Please rate my help++++Thanks for using FIXYA
Dec 01, 2009 | LG 20LS7DC 20 in. LCD TV
Stays in standbye and will only flash green (power on) twice before staying in standbye
The 6 inverter transformers on the bottom of the picture is the problem and what need to be tested.
Unplug the 6 wires that goes to the LCD screen. Use a multimeter to test for resistance from each output plug on the board. The one without the resistance is the bad one.
If this doesn't locate the bad one this way, Each plug should give out DC voltage if working properly. Test each plug for voltage.
The TV will automatically turn off in a couple of seconds like before. You'll have to keep pushing the power button to test each output plug for voltage.
Soon as you find the bad Inverter Transformer, just solder in a new one and the TV should work fine after that.
The part # for the Inverter Transformer is LTZ2PC0MS008.
Here's two places to get them:
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
Apr 23, 2009 | Televison & Video
My flatscreen emerson tv will not turn back on.
I found a way around this problem. When this happens, don't use the remote.
Walk up to the TV, then HOLD DOWN the power button and while the lights are flashing, start pushing the menu button on the TV at the SAME TIME.
Then your screen will turn on. No idea why this works. Just stumbled on it while getting ********** that this TV, I had less than a month, suddely would not come on anymore. I was about to unplug the whole thing to take back to WalMart and just started pushing button combinations and found this worked.
Mar 30, 2009 | Emerson LC320EM8 32 in. LCD TV
I have a sva vr-30 that wont turn on no red or green lights
If you don't have a standby light and if the unit does not even make any clicking sounds or try to come on at all then you have a bad power supply that will need replaced.
Jan 03, 2009 | SVA-USA VR30 30 in. HD-Ready LCD...
TV will not turn on.
the power supply / board is shot and needs to be replaced. You can find them cheaper online, have it shipped to you and then find a local tech to replace it cheaply.
Dec 29, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Will not turn on
could be the power supply or the logic board
Sep 04, 2006 | SVA-USA HD4208TIII-VR 42 in. Plasma...
SVA-USA HD4208TIII-VR 42 in. Plasma Television Logo
Top SVA-USA Televison & Video Experts
Dave Naylor
Dave Naylor
Al Clark
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
