Question about Brother LS-2125 Mechanical Sewing Machine
Brother Industrial Machine Tension
I have an industrial brother sewing machine (model DB2-B705-103) & wheni sew the top thread is fine but the underneath has lots of loops & when i pull the thread out of the machine it is quite tight & needs to be pulled with force from the underneath.
I have no manual for this machine & am not sure how to adjust the tension on this - or if this is a bobbin/bobbin case problem?
  • Anonymous Mar 21, 2014
    Industrial sewing machine manual
  • Anonymous Mar 28, 2014
    i have the same thread weight on both.. but still a lot of loops in my thread underneath and not even able to see the bobbin thread on top
This is an answer to another person with a similar complaint. Try the suggestion below, it may fix the problem.
From your description it appears that you have tried tension settings on the upper tension control adjustment knob without success.
Check that the bobin tension is adjusted correctly by taking out the bobin complete with the spool.
Pull the cotton thread and it should be a smooth light pressure if the tension is correct. If it is tight to pull or pulls freely then adjust the tension screw which is found on the outside of the bobbin. The screw is very small and requires a minature size screwdriver. The adjustment will only be a slight turn of the screw one way or the other to obtain the correct tension(depending if it was loose or tight).
Once this is set reinstall the bobin and tread up the machine, hopefully with the upper tension set at approx."2" the machine will sew correctly.
Posted on Nov 30, 2008
Brother Industrial Machine Manual db2-b736...do you have a manual
Brother has manuals for most of their equipment on their support page. The DB2-B736 manuals are here: http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=B736%20%20003#.U211q2SFr3g . The direct link to the user's manual is http://www.brother-usa.com/VirData/Content/en-US%5CIPD%5CConsumer%5CInstructionManual%5CIM_DB2_B736_EN_7235.PDF .
I hope this helps.
May 10, 2014 | Brother Sewing Machines
E-40 how to set
Here is the best advise any professional sewing machine mechanic can offer given the information you supplied.
You set your Brother industrial db2-b737-403 by turning assorted wheels, knobs and levers.
Mar 23, 2014 | Brother Sewing Machines
I need a pdf manual for the Brother Industrial sewing machine model DB2-B755-5. Hope someone has the manual
You can go to www.brother-usa.com and look for your model but I saw only similar as in DB2-774 and a couple of others under the industrial machines. Maybe they will be close enought to answer your questions. They are free to download, if that doesn't work call Brother at 1-877-276-8437 and I am sure that they can help you locate one. Good luck, you have to wait until Monday to call them.
Sep 17, 2010 | Sewing Machines
MANUAL FOR BROTHER INDUSTRIAL SEWING MACHINE DB2-B755-3
Go to brother.com . From there you will need to enter the model number and serial number to get the file for free good luck
Jun 01, 2009 | Sewing Machines
How do I thread this machine?
Manual here.
http://myweb.tiscali.co.uk/stitches/BROTHER-DB2-B755-MKIII-MANUAL.pdf
May 23, 2009 | Brother Sewing Machines
Industrial sewing machine top thread breaking
The brother DB 2 series of machines do not use a needle with a flat side. the needle system is DBX1 and are available from size 10 to size 20.
Try using the right needle for the machine and the right size for the thread you are using. this should make it better
Dec 19, 2007 | Sewing Machines
Brother DB2-B755-3 industrial sewing machine
I have the manual in pdf form here
Oct 28, 2007 | Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
433 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
