Question about HP Office Equipment & Supplies
My hp photosmart c5200 All-in-One will neither print from the PC nor copy. It tells me there is a cartridge problem. When I switch on the PC and the printer, and check the status, the black cartridge is 75% full and the colour cartridge 50% full. Bur when I try to copy or print, the indicated level of the black cartridge drops to zero and the copy/print fails.
  • 3 more comments
  • jgmheal Nov 16, 2008
    I have removed and replaced both print cartridges, and unplugged and reconnected the power. The printer now immediately records a cartidge problem, and the computer display indicates a problem with the black cartridge. The status indicator records no ink in the black cartridge. Clearly, no ink has been used since the black cartidge was recorded as 75% full. As the cartridge is a recenly installed (genuine) HP350XL, and our use of the printer is very moderate, the 75% reading is entirely realistic. Grateful for further advice.
    I have wiped the black cartridge contacts, and the contacts at the back of the black cartidge carrier, with a dry soft tissue, but he printer does not work and records a cartridge problem.
    can you therfore advise?
  • jgmheal Nov 17, 2008
    i styhere a common household equivalent of isopropyl alcohol, e.g. white spirit? In the meantime I have wiped the contacts again more thoroughly. The staus indicator now says the printer is ready and that the black cartridge is 75% full. But it still won't print, and the printer display still says cartridge problem? Any further ideas, or should i try a new cartridge?
  • jgmheal Nov 18, 2008
    Thganks for your help. The printer is now working with a new HP 350 black cartridge. This seems to mean that the previous HP 350XL developed a fault when less than 25% used. Is it worthwhile to clean the contacts on that cartridge for storage and later use, and if so what should I use? Alternatively, am I entitled to a part refund?
  • 849 Answers
U should get one or more prints with in a week or so for smooth running of printer. u could not claim the refunds as a long time has gone.
Posted on Nov 18, 2008
  • HP Master
  • 541 Answers
If you go on the hp website click on live chat and they will help you
  • HP Master
  • 6,487 Answers
The next thing to do here ios to try a new cartrudge so we can really check if this is a problem with that cartridge that you're using.....
Posted on Nov 17, 2008
  • HP Master
  • 1,879 Answers
Cleaning the contacts and re-seating the cartridge has been performed.
Access the printer setup menu and reset the printer to factory default.
"As the cartridge is a recently installed (genuine) HP350XL, and our use of the printer is very moderate, the 75% reading is entirely realistic."
Possibility of a cartridge gone bad OR the unit is experiencing hardware failure in reading it correctly.
Posted on Nov 16, 2008
  • monk3ybidzness
    monk3ybidzness Nov 17, 2008
    To eliminate the cartridge as the culprit, the next logical thing to do is to replace the cartridge.
    President:
  • 2,712 Answers
OK, since you have tried all the basic steps already, it could be one of two problems:
1. Faulty cartridge (although it is original, there can be problems with the contacts, etc). Try an altogether new cartridge, if possible. BTW, the recommended cartridge is a HP 74 Black Inkjet Print Cartridge (CB335WN) or HP 74XL Black Inkjet Print Cartridge (CB336WN)
2. Faulty contacts/circuitry on printer. Try to clean the contacts on the printer with a Qtip dabbed with isopropyl alcohol and see if this helps. If not, servicing may be required.
You could also try a clean install of the printer software. (It is different from a regular install) Details are here:
For XP (Replace the word 'camera' with 'printer' in the article. Procedure is the same)
For Vista
Hope that helps!
ID
  • 734 Answers
There must be sum shorting problem in cartages or the printer
  • HP Master
  • 13,433 Answers
There is most likely a fault in the cartridge - cartridge carrier, I suggest you remove the carts, clean the contacts in both the carts and in the carrier, turn the printer off it not already, turn it on, it asks to enter the carts enter the carts and press ok when done, see if it works now.
Posted on Nov 14, 2008
  • HP Master
  • 685 Answers
Try taking out the cartridges and replacing them if that doesnt work then try unplugging it for a couple minuets and then plugging it back in and try it then
  • Juanita Vega
    Juanita Vega Nov 17, 2008
    ok sence you did all that have you tried reinstalling the printer that could be the problem
  • HP Master
  • 19,396 Answers
Replace the black cartridge, it is probably defective.
  • Ginko
    Ginko Nov 14, 2008
    First try power cycling the printer, do do the following:
    1. Remove both cartrige.
    2. Unplug printer USB and power cord .
    3. Turn computer off.
    4. Plug back everything and restart the printer and the computer.
    5. Reinstall cartridges.
    6. Test printer.
    If that does not work than it is probably a faulty cartridge, replacing the whole cartridge set is better.
Hp photosmart 5510 is giving ink system error 0xc19a0042
It either telling you your ink is low,or cartridges need a cleaning,which your machine will do that for you.
Nov 17, 2014 | HP Photosmart 5510 Wireless e-All-in-One...
Incompatible print cartridge
Take out the print cartridge. Clean the points on the cartridge with cotton swab and try using it again.
Nov 04, 2009 | HP Photosmart C4480 All-In-One InkJet...
My HP Officejet J6480 all-in-one gives me Cartridge error: Cartridge on right must be replaced. I have changed the cartridge but still get the message.
These types of 'severe' cartridge errors/alert messages (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings: http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges): http://www.youtube.com/watch?v=8fE-IM4AVMc
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
Oct 03, 2009 | HP Office Equipment & Supplies
Where to plug in phone port for the HP c5280
I'm sorry but the C5200 series printers do not have a phone port. It is not a Fax capable printer. It scans, copies, prints and does photo prints.
The only ports you have are for the USB cable and power cord.
Here is a manual link for reference.
HP C5200 Manual
Thanks for using Fixya.
Sep 26, 2009 | HP Photosmart C5280 InkJet Printer
I have a HP Photosmart C5200 - pages are printing pink and red streaks in pictures
the print head for magenta and cyan (might be also Yellow) is dirty. you can try to clean it with warm water, or replace a new print head.
Jul 31, 2009 | HP PhotoSmart InkJet Printer
HP Photosmart C6180 all in one, does not copy or print anymore.
put the old cartridge back, if there have same error message then tell me what error message is, if not that's mean new cartridge is defect.
Dec 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
I have a hp photosmart c5200 printer. how do you increase the number of copies you want to reprint?
go to file>>print>>on the right hand side of the window...you will see an option:Number of copies....increase it to your requirement.
Nov 26, 2008 | HP Office Equipment & Supplies
Printer not printing properly
When you changed the cartridges, the printer automatically prits a test / calibration page. This page must be placed in the scanner, then you have to press the "scan" key (the green one). It will calibrate an align the system. Then you'll be able to print.
May 03, 2008 | Office Equipment & Supplies
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
