LG DLEX7177 Dryer Logo
Posted on Apr 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you take apart the LG DLEX7177 Dryer to fix it?
Vicky
Level 2:
New Friend:
  • Expert 42 Answers
  • Posted on Apr 25, 2013
Vicky
Expert
Level 2:
New Friend:
Answers
42
Questions
Helped
11249
Points
123
This link should take you to the repair clinic. Their videos are great. This is how I learned to get into mine. Good luck.
http://www.repairclinic.com/LG-Dryer-Model-DLEX7177RM-ID-882536-Parts
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
Lg dlex7177wm heating element
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
This is a specialised job and should only be attempted by technically competent persons.
Making a terrible noise
its cloged or the pad behind it is burned up
Dryer is not heating, where do I find the heating element
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
The dryer will not turn on, the light works, but cannot turn any cycle on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
1helpful
2answers
Unable to turn on dryer. Light works, but pushing initial start button does not start. Electric heat.
I experienced this issue. I replaced the main control board, part number EBR36858803, which I ordered from Amazon. Problem solved for just over $100. Relatively easy fix.
2answers
My dryer says check filter? Where is that at?
Lint filter,, usually a slide out screen,, some are in the lower opening by the door
Need to replace heating element. What panel do I remove to gain access
the back panel best to take the lid of and have a look down the back to make sure thats normally where heating elements are.
Model DLE177WM Dryer has completely stopped, no power showing to appliance, but there is power to the outlet. Any suggestions to trouble shoot/
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Top LG Dryers Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Dryer Expert? Answer questions, earn points and help others
