Home | Toshiba | SD-P1400 Portable DVD Player with Screen | Toshiba SD-P1400
Toshiba SD-P1400 Portable DVD Player with Screen
Problem for Toshiba SD-P1400 Portable DVD Player with Screen
Toshiba SD-P1400
By Boneli on Nov 19, 2006
I have the same problem describe by others where the DVD player just makes the noise to read the disc but can not read it. It will eventually say, no disc. Tried putting in several other known working disc with same results. Looked inside and cleaned the laser with no luck. I moved the laser mechanism back and forth to see if this was jammed but it was not. Seems like it's on a belt system. What can be done from here and what can I expect to pay for someone to debug the device?
Thanks
Please e-mail your response to wabakimimaps@hotmail.com if you can.
Barry
Same Problem
Jun 16, 2008
-   Player was working fine, then all of a sudden it didn't. I get a disc error reading on discs that work on my other standard player. If the lens is bad, how and where do I take it to get a new lens installed. Took it back to Best Buy, but they claimed they could not repair it. Said their computer listed it as "unrepairable". So, does that mean I have to buy a new one. Thanks. Marti1935.-   mari35
Solution #1
posted on May 24, 2008
Not Rated)
jonniewalker
Rank: Guru
Rating: 88%, 568 votes
the lens is bad and need to b changed
Was this helpful?
Yes
No
Popular Solutions for Toshiba SD-P1400 Portable DVD
Questions and Unsolved Problems for Toshiba SD-P1400 Portable DVD
Do you recommend Toshiba SD-P1400 Portable DVD Player with Screen?
Answer
Answer
Toshiba model # SD-P1400 was working fine however when we tried to play recently the screen was... (More)
Answer
switch power on/off no good .. broken for sometime i did pushed or press very hard with the... (More)
Answer
Model # SD-P91SKN will no longer spin the discs. When I try to play a disc, it reads "No Valid... (More)
Answer
I have a Toshiba SD-P1400 portable dvd player. I can hear the dvd but there is no picture. HELP!!
Answer
The player does not read the DVD and some VCDs. I have had the problem for months
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba SD-P1400 Portable DVD...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
