Question about LaCie BRICK (301063U) 300 GB Hard Drive
Probolem with power cable
The power cable is all of a sudden giving me trouble. I was transferring some data on another computer and all of a sudden the power went out on the drive and I noticed that the green light on the transformer was flashing. Now whenever I plug it in, no matter where or on what computer, the green light flashes on the transformer and I can't turn the drive on.. or it will work for maybe 2 minutes then the light starts flashing and the power goes out on the drive. what does this mean? How could it have happened? I wasn't doing anything irregular. Normally I leave my drive plugged into the computer and the power all the time and I have never had this probolem. Only now. Any help would be greatly appreciated as there is alot of important data to me on that drive and I don't see any reason why it should have stopped working!
    Novelist:
    Champion:
  • 382 Answers
Power loss on a drive even if it is not transferring could be severe. Especially with Lacie gear. The bridgeboard ( which is the chip that transfers the content between the drive and the ports on the enclosure ) can fail instantainously if power varies or is cut. The major concern is if the internal drive is effected ( in the enclosure .)
Those things are cute, but not that reliable.
Posted on Oct 28, 2007
SOURCE:
How to transfer text messages from Samsung galaxy to computer?
If you want to back up all the text messages from Samsung galaxy phone to a computer, the best method is using a data transfer tool, then you can finish this thing in a fast time.
Prominent Samsung Messages Backup Software
Transfer Text Messages from Samsung Phones to PC
Nov 27, 2017 | Samsung Computers & Internet
Wd 1600 not working
Western Digital My Book hard drives use USB 3.0 and USB 2.0 speeds to transfer data from the hard drive to the computer and vice versa. When your My Book external hard drive is not performing properly or not turning on, you can troubleshoot the problem before sending the hard drive back to the manufacturer. Correctly powering up and installing the My Book are essential for transferring information and avoiding corruption.
Run your fingers up and down the power cable that connects to the back of the My Book hard drive and the wall outlet in your home. Feel for breaks or tears on the cable and replace the cable if needed. Check the pin on the back of the hard drive where the power cable meets the drive. Make sure the pin is straight and will make contact with the power cable properly. If the pin is bent, send the hard drive to Western Digital for repair. Plug a different device into the power outlet you are using to make sure it works properly. Use a device that you know powers on correctly. b> Slow Transfer Rates b> Open your computer's tower and check over the PCI adapter card that gives you the ability to achieve USB 3.0 speeds. Make sure that the adapter card is installed correctly per your manufacturer's installation manual. If the PCI adapter card is not installed correctly, you will not be able to transfer data in the 3.0 speed. Disconnect any other external hard drives connected to the system. When two hard drives are connected via USB, they share the transfer rate bandwidth and slow your transfer speeds down. Run a Windows Update to change the USB driver on your computer. Click "Start" then "All Programs" and then "Windows Update." Run the update and choose your correct USB 3.0 driver from the list. Click "Install" at the bottom to install the driver. Hope this helps.
Jan 05, 2013 | Western Digital My Book Essential Edition...
Transfer files from samsung s8000 to computer
it easy u can use data cable for data transer.
when u will insert cable to your computer's usb slot it will asked to select media storage on your s8000. now your s8000 is ready to recive data to your computer
Jul 29, 2012 | Samsung Jet S8000
I have a 320 GB Simpletech external hard drive in dark cherry with considerable dats and pictures stored in it, but I have lost the cable or adapter that may drive the unit. With the USB cable, the...
You usually get this cable from nearest Bestbuy, Staples or Walmart store.
You can take the SimpleTech SimpleDrive to the store and ask for the adapter and they should be able to supply it.
This way you wont have trouble of getting you wrong part shipped as well.
Thank you for contacting FixYa
Nov 20, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Can I transfer data from my itouch to my iphone?
In fact, you can use an iPod to computer transfer program to backup the data files form ipod to your iTunes first then sync to your iPhone.I personally use iPad/iPhone/iPod to Computer Transfer.It helps me to transfer my songs/videos/photos/playlists etc from ipod to my computer directly and safely.It works well for me,you can give it a try.
Free download
Hope it helps.
Oct 01, 2010 | Apple iPhone 3G
Data transfer between PCs
The easiest way is with a USB data transfer cable. You just plug it into both computers, run the software and select the data to move. The sit back and in just a few minutes the data is moved. You should be able to get the cable from a local computer store, if not contact us at the address below. We have them available for shipment to you, they run $18.00 plus shipping.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 14, 2009 | ATI POWERED BY RADEON 9200SE 128MB DDR...
Where do I connect my camera cabel to my computer?
Some cameras have a multi-use cable which can be used for both data transfer or copy, and video output. Most cameras I have worked with usually have two cables, one for video playback and the other for data transfer or copy to a computer or other device. Most all cameras today use the convince of the standard computer USB access.
Most cameras have a cover made of either rubber or plastic which can be folded back to reveal connectors for mini-USB and video outlets. The appropriate cables must be used to connect to video or a computer or other device.
It is advisable to read your user manual for information on usage of the video and the data transfer cables and the software, if that is what you need.
I also suggest to skip all that and use a card reader, no more hassle. A card reader will give you more freedom without having to install software to see your photos or other files.
Nov 08, 2009 | Canon PowerShot A570 IS Digital Camera
Data transferring trouble
I think first you want to use the correct data cable for your phone. then you have to install the drivers for your phone in to your computer. Then only you can transfer files between computer and phone. You can download the drivers from the internet.
Jul 27, 2009 | LG Shine KE970 Cellular Phone
Motorola L6i usb data cable software
my motorola l6i cannot connect with my pc through data cable. so pls give me USB Data transfer sotware .................send software on my e-mail id....................www.raj_veer.19@rediffmail.com
Aug 09, 2008 | Motorola Mobility Mobile PhoneTools 3.0...
Trouble with usb
This may not be any help, but I had the same problem with my MP3 player and it was the cable that was buggered. I bought a new one & all is good again. The old cable can still be used for charging, but not for data transfer. Don't know why.
Aug 22, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
LaCie BRICK (301063U) 300 GB Hard Drive Logo
149 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
