The battery is an Olympus LI 428 which came with the camera, an Olympus FE 280/X-820. I have only ever charged it twice in eleven months, as I don't use the camera much. The battery does not appear to be charging. Help please!
-   I started using the my Olympus FE-340 for the first time in a few months and every time but once, the charger flashes when inserted and the battery doesn't charge! What's going on?
-   fluteymal
Dec 27, 2008
-   My battery chrager is also flashing red. It never did that before, it was always a steady red light. C-765-   Guest
Dec 12, 2008
-   i have a olympus fe-330 and i have a problem with when i put my battery in the charger it comes up with a blinking red light! whats wrong?-   Guest
Another way I found was when this happens, to push the battery to the point the light will turn on, when it starts flashing slide it off then back on. Do this a few times so it charges a little, then you should be fine to leave it on.
If the charger is flashing red then the battery was allowed to fully discharge. You can either buy a new battery or force the charger to charge the battery. The way you do this is by applying a voltage across the charging terminals while inserting the battery. I opened the case of my charger and attached wires from a AAA battery to the corresponding wires attached to the charging deck (+ to red and - to black). Then I slipped the battery into the charger and plugged the charger into tho wall. The light should illuminate solid red (no flashing). Then immediately (and carefully) remove the wires from the charger.
Was this helpful?
Yes
No
Popular Solutions for Olympus FE-230 Digital Camera
Im trying to download pictures in to my pc. Camera turns on with response ---- card setup---power...
(More)
Im trying to download pictures in to my pc. Camera turns on with response ---- card setup---power off format? Please help, this is pretty new camera
battery does not fully charge.Charger only charges battery for about a minute and then battery lasts...
(More)
battery does not fully charge.Charger only charges battery for about a minute and then battery lasts for about 10 minutes in camera
When I turn the camera on the zoom goes in part way and back again a couple of times. I have the...
(More)
When I turn the camera on the zoom goes in part way and back again a couple of times. I have the dial switched to auto but there is no picture on the screen. I can get the picture by turning the dial to another function and then back to auto. The picture on the screen is also out of focus.
