Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Top Freezer temperture warm, not freezing food
Making a clicking sound from bottom section on floor
    President:
  • 1,462 Answers
Clicking noise is probably compressor relay operating and compressor not starting. probably compressdor faulty
Posted on Nov 14, 2008
Freezer has ice fridge is warm food going off
change the temperature sensor its not working fine
cause the compressor is working all time never stops
this is located inside a metal box with a dial
Sep 16, 2015 | Refrigerators
Gladiator Freezerator wont stay frozen in the bottom portion. It will go to temp when temp is mved, but then start to warm up. Why?
If the bottom freezer section of the Gladiator Freezerator is thawing out the usual cause is from the coils in the back of the top refrigerator section being iced up. The ice blockage prevents the fan from circulating cold air into the bottom freezer section. These units have a design flaw due to the defrost drain freezing up preventing water from draining out from under the coil. The long-term solution is to remove the back wall of the refrigerator section to get to the coil, thoroughly defrost the coil making sure the drain tube is clear, then wrap a couple turns of #12 or #14 copper house wire around the bottom of the defrost heater element and run it a few inches into the drain tube. Advise unplugging the unit when you do this.
I've had this fix on my Gladiator for a couple years and it has been working perfectly ever since. The freezer stays a constant 0 degrees F and no more thawed out food.
May 09, 2014 | Gladiator Freezerator Top Freezer...
1988 sub zero refrigerator's freezer is warm on the top and not making ice
Sounds like you have a fan problem around the evaporator in the freezer, it is possible it has failed and won't move air within the freezer section anymore. Cold air drops and heat rises.
Good Luck
Mar 21, 2013 | Sub-Zero 561 / F
The fridge top section is getting colder and freezing some items. The freezer section...the first tray apperas just alright but the bottom tray is warming and the food is thawing.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Fisher and Paykel Active Smart® E522BR...
I have a GE Profile Bottom Freezer Refridgerator. Everything I put in the fridge freezes. When I increase the temperature, it stays low.
Make sure you do not have items blocking air flow to the temperture sensor at the top left side of the refrigerator. Another thing to check would be air leakage at the air duct at the bottom back of the fresh foods section. Also, at that air duct, make sure there is an electrically activated dampener door inside (I've seen them missing), and that the damper door is not broken.
Mar 14, 2011 | GE Refrigerators
LG GR431SCA fridge will not cool properly and top half of freezer and ice maker section will not freeze. The bottom half of the freezer (below the shelf) freezes well, but above the shelf and the ice...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 04, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Our Smeg SR640XA side by side refrigerator is making strange puffing noises at the bottom section of the freezer. It puffs four or five times and then it sounds like something is dribbling in the back of...
It is the defrosting heating elements and sensors that has gone bad.
Check for glowing light at bottom of the back panel. Turn the freezer section off and contact Smeg!
Mar 14, 2010 | Smeg FA561X Side by Side Refrigerator
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag top freeze freezes food in the refrigerator section
this used to happen to me, it is accualy the ice macine make sure you empty the ice compartment regularly
Sep 05, 2009 | Maytag Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
