Question about Canon PIXMA MP150 All-In-One InkJet Printer
Paper feed pulling to the right during paper feed
Hi
I have a Canon Pixma MP 150 purchased in Aug 2006. I have recently changed the ink cartridges (both Colour and Black).Please note...The ink did run very low. Since then, the printer will not paper feed properly anymore. It now says system error 5100 and flashes E2 on the printer. I have followed all maintenance procedures according to instructions with no success. Is this an easy fix or a case of just buy a new one?
Thanks for your help
Dee
  • ayeaye111 Nov 22, 2008
    I have the same problem with my Pixma 150
  • mrzz Nov 30, 2008
    Same problem with the loaded paper being pulled to the right. Based on how it is pulled it jams during print and then displays the the error (5100). I have used this printer for more than a year with no issue, but suddenly this problem occurred.
    Guru:
  • Canon Expert
  • 183 Answers
Dear all,
Error code 5100 indicates CR (carriage return) error occurs. There are 2 possibilities of this case: Film timing **** strip is dirty or carriage part is faulty. Look inside your printer. There is a film, installed in horizontal position. Try to clean this film first;wipe carefully with moistened clothe. If the problem still persist, it seems that carriage is faulty.
Regards,
Source:
Canon Inkjet Printer Forum
Posted on Nov 28, 2008
How to fix error 24 for mp 160????
Hi
This is a purge unit error hence you need to check and make sure the purge unit is working fine. If not you need to clean it.
THE PURGE UNIT IS THE ONE ON THE RIGHT SIDE WHERE THE CARTREIDGE RESTS WHEN YOU TURN OFF THE PRINTER.
And at the same keep the below mentioned error list for your future use.
CANON MP140, MP145, MP150, MP160 ERROR CODES RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16-E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Jul 31, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Tip
Code error PIXMA MP160 All-In-One InkJet Printer
this error list PIXMA MP160 /150 All-In-One InkJet Printer
CANNON PrintersMP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported inkcartridge is installed ,
or the ink cartridges are notinstalled properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera /video camera does not support Camera
DirectPrinting
E14 The Ink cartridges whosedestination are wrong
E15 Ink cartridge is notinstalled E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature riseerror
E27 Waste ink absorberfull or platen waste ink absorber full
E28 Ink cartridge temperaturerise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
on Mar 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA mp 150 printer error msg reads E3 or paper jammed
it is the problem caetyridge adjust cartridge part no 40=41,830=831 or cartridge nozel is fill extra ink clean it not software open your cartridge and clean cloth
Jul 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error E3 when no paper jam
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Under one year old pixma mp150 all in one/ changed ink cartridges/error code E2 / saying no paper ????
I have had a MP 150 Cannon Printer with a E3 paper jam code..when NO visable paper jam is present ! Your No paper problem may be as a result of similar issue due to a small piece of paper stuck in the roller assembly out of sight. TRY this, Turn printer off wait (10 seconds) or more then turn printer back ON and listen for roller assembly to turn the ROLLERS and then FORCE FEED
a sheet of paper into rollers until it PULLS paper through and SEE if any scrap of paper comes out with the sheet !! If this works you should see that it clears the code. and resets your printer.
Let me know if this works. Phil at palcando@yahoo.com
GOOD LUCK !
May 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have PIXMA MP 600 PRINTER that has a paper jam as I fed used paper back into it /ink was still wet and apparently paper has stuck together and jammed. How do I clear
clear the jam paper
1) pull slowlly the jam paper back as possible as you can, usually the jam paper could be broken as pulling
2) open the cartridge area find the paper pull slowlly forword paper direction as possible as you can and try to take out any pieces paper behide the cartridge (between paper input roller and ink cartridge
Jan 24, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Use of High yield Cartridges in Canon Pixma 150
have u tried to remove the cartridge again, proably some contact problem
May 27, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma MP 610 Pixma Printer
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E22 Carriage error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
May 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Mp 160 don't work
hi dear
this the error code
Direct Printing
E22 Carriage error
E29 EEPROM error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
- unplug cable
- plug cable
Run the software.
oke
Jan 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
136 people viewed this question
old marine
old marine
