Question about Car Audio & Video
A DENON DCA-660BL car amplifier after a certain volume its shuts donw the subwoofer.It's not the sub's problem.I connected a different amp and it worked fine.Any opinions?
  • autoradiodra Nov 14, 2008
    Thanks for your answer!I've checked these things and they all seem fine.Therefore I think the amp has the problem.
  • 146 Answers
It could be a few things. Those amps have pretty sophisticated monitoring circuits that watch for impedence mismatch, current draw, clipping, overdriving, etc...
I would double check the power going to the amp. You should be using 8 AWG wire or larger, be connected directly to the battery, have an inline fuse at the battery connection, and the terminals should be crimped and/or soldered. The connections here are critical. The ground wire must be terminated properly as well. Did you use a lug and a screw drilled into the body? If the paint scraped away from where the ground is connected so there is no ihgh resistance termination? If you think the power is good then your amp may be failing.
Posted on Nov 14, 2008
How can I connect a subwoofer to this device (denon pma-520) http://www.hifiengine.com/manual_library/denon/pma-520.shtml?destination=node%2F14208
Look around for a subwoofer which has speaker level inputs.
Something like this;
https://www.parts-express.com/dayton-audio-sub-1000-10-100-watt-powered-subwoofer--300-628
Jun 08, 2014 | Denon Pma-520 Integrated Stereo Amp...
Connecting a passive subwoofer to a denon 2113
you need another reciever/amp to power that sub, because that denon reciever is designed for a powered sub,. if you have another old reciever/amp laying around, you can connect the sub out from the denon into an auxillary input of any old reciever/amp, (switched to that input) with speaker wires from old reciever/amp to the passive sub
Mar 05, 2013 | Denon Avr-2113ci 7.1-channel Home Theater...
I have a kenwood kac-9152d amplifer and it works just fine for about 10 minutes then just shuts off and subs dont work, about 30 seconds later my amp turns back on with the subs.
make sure it's well ventilated. If there's no air flow, then there is no way of cooling down and to protect itself it will shut off. Make sure the speakers are wired correctly as per amp specs. too many subs or subs connected improperly can draw too much current and shut the amp off, but you will notice this when you turn up the volume to a certain point and the amp shuts down.
Aug 30, 2011 | Kenwood KAC-9152D Car Audio Amplifier
Will the Muteki sub amp work with a different receiver that has no trigger.
My subwoofer recently burnt out because I had it plugged into a different amplifier.. I wouldn't recommend it. Sony has released the sub to suit that system.. Do keep in mind that I did have bass boost on with the sub up full (Which didn't matter when I had it connected to the Sony amplifier..).
Proceed with caution.. I would recommend turning the sub down and using the sub volume control on the amplifiers settings to change the volume.. Just do not run it at a pace where it looks like it is stressing.. When I say stressing I mean, looking like it is going to jump out of the enclosure..
-Dubkingz
Aug 17, 2011 | Sony MUTEKI HTDDW1600 Theater System
I have a jl 500.1 and a 8w7. The sub is playing but not really it will play sometimes but most of the time i am getting almost nothing. Am i using the wrong settings or a bad connection or blown sub?
Sounds like a bad rca connection. You need both rca jacks to be plugged in from your head unit, both left and right or you will not have full power you'll have half power to your sub/subs. Check your sub with a volt meter and see what it reads. Make sure if your head unit has a sub volume make sure it's turned up. Alot of people don't realize they have a seperate subwoofer volume on there deck and it's set to low, so check that. You could have bad rca cables. If all that is ruled out(best way by trying a different amp) the amp itself might be having problems. Don't think it would be in protect mode either.
Let me know if you have'nt allready.
Nov 14, 2010 | Jl Audio 500/1 Car Audio Amplifier
My punch 550.2 amplifier's thermal light is turning on and off
well, hopefully the amplifier was wired correctly. But either way there are so many factors that can cause this problem... But the biggest one is the amplifier must have been sending some distortion to your subwoofers which a subwoofer can take a certain level of distortion and be fine but too much will blow any subwoofer even the highest of high end subs at a high volume... when your subs hit the point of blowing they will tend to just blow out one at a time... they don't just pop both right away. I'd say get the sub that isn't blown off off of the amp before it blows too... distortion is clipping most of the time... when you destroy the subs it will eventually work it's way to the next component in the system which is your amp and then you will be out an amplifier and subs. save yourself the headache.......
Dec 12, 2009 | Rockford Fosgate Punch P550.2 2-Channel...
AVR-1910 & Bose Lifestyle 35 setup
Bose Lifestyle (and all Bose-amplified speaker) products and their speakers are SYSTEMS and should not be split up or intermixed with other brands or models. Damage will probably result. Proprietary connectors provides a clue.
The digital audio out should work with the Bose. You could still use your Denon to drive a conventional sub in your scheme, but you would have to manually match volume with the Bose. Or go Full Monty and buy a full complement of speakers for the Denon, retask the Bose and slave its sources to the Denon.
Dec 05, 2009 | Audio Players & Recorders
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
Subwoofer Turns Off when volume is turned up
check your earth from the amp i had same prob and the vibration broke earth connection once secured it was fine
Aug 24, 2009 | Pioneer TS-SWX310 Car Subwoofer
Car Audio & Video Logo
343 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
