Question about Epson AcuLaser C900 Printer
HELLO PRINTING FADES RIGHT HAND SIDE OF DOC ANY ADVICE ,THANKS IN
Hello there is a growling sound when printing as If cogs are not meshing correctly I have replaced all color carts ,Also printing fades on right hand side of paper ,Any help would be great
Thanks for your time
Warm Wishes Michael
Hello I have sorted the growling sound out with a shot of WD40 lube ,but have not sorted out wht the cyan does not print clearly any advice would be helpfull
Posted on Nov 15, 2008
HP Laserjet P3015 fade
This could be because of few reasons, The Ink powder is not rotating inside the drum to give you the correct output.
Remove the Toner and Shake it a bit. Try to print.
Check for Firmware update available for your printer. There are Fixes released for known issues.
Click on the link below to find solution for all Print Quality related issues for your printer
HP Laserjet Print Quality Solution
Hop this Fixes the Issue
Regards,
Sean
Apr 22, 2013 | HP Laserjet P3015X Printer
HP Color Laserjet 2600n not printing heavy color doc evenly faded on the left side and normal on right side.
You are going to need the laser optics cleaned. Common problem. Usually affects one color more than others but light print on one side is a symptom of dirty laser optics. The laser units have to be removed before cleaning and this requires disassembly of the printer.
Dec 29, 2009 | Office Equipment & Supplies
Hello there, i have a canon MP370 which i have been very happy with and had no problems,however the machine when it prints now all the colours are very faded and banding occurs right accross...
Check your cartridge first and take a look if it is not running out of ink,try replacing it with a new one then on your printer maintenance do head cleaning,then print nozzle check to see which color has a problem,if it doesn't change try to look for chemical solution that are being use to clean print head. soak the print head,dont touch the head with your bare hands or anything hard its sensitive.
Sep 12, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
I have fading on the right hand side. Printer Dell 3100CN
Dell printers are junk. But you have put a lot of money into this thing. Check the alignment of the black drum, could be that something is keeping if off track a little bit.
May 26, 2009 | Dell 3100cn Laser Printer
Hello buyerfs,
Well I got good news and bad news for you. The good news first, this problem is common and is fixable. It has to do with aligning the page sensors and the DRUM. Now for the bad news, remember what you said DELL told you? "They said buy a new printer" guess what, they were not kidding, the work involved with adjusting the sensors and the DRUM, will cost you the price of the printer alone in labor. It is a tedious job and requires adjusting three systems in unison. I hate to tell you this but, DELL was correct, but if you don't think so, try to shop around for a repair shop to work on the problem, but first get an estimate.
I hope this helps.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 11, 2009 | Dell 3100cn Laser Printer
Prints faded
Hello mvjv,
To solve the faded prints you need to clean the printhead twice by going to the software and click the "?" mark icon on the upper right corner of the software window and then under General Links select Maintenance then choose Clean Printhead - do it at least thrice to unclog the printhead system. Then try making prints... If still cannot solve call Kodak Technical Support.
I hope I have been some of help.
Nov 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lexmark x2480
Is it pulling through only on the right?
Or left?
Either way [sounds like] it needs taking apart to put the paper feeder cogs back inline.
To the right would suggest the easier option of the bar which is visible from where the paper exits has dislodged and the cogs sit on the left hand side of it.
As the paper feeds through it's unlikely the other option as those cogs are what feeds the paper through but they are intricate so it can't be ruled out.
Not much fun if you don't like doing mechanical maintenance I guess!
Aug 01, 2008 | Office Equipment & Supplies
Print fading down right hand side
I was able to fix it by taking off the top of the printer. This involved taking off 4 screws on the top of the printer. I then had to disconnect the wires going to the control panel by unhooking them from the right side. I then located a thin rectangular box which I'm assuming houses the laser. I removed this with 4 more screws and turned it over. There was a little metal flap that I moved back and below was the mirror the lasers shoot on before going onto the toner.
In the same spot where I was having fading, I noticed a lot of toner on the mirror, so I cleaned it of, put it back together, and the fading was gone.
This was after I tried a new toner and maintenance kit.
Hope this helps
Apr 22, 2008 | HP LaserJet 4350 Printer
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Epson AcuLaser C900 Printer Logo
543 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
