Question about Dishwashers
Diplomat adp 8520 dishwasher no hot water
I have a diplomat adp 8520 dishwasher which is working fine , no fault codes, it is connected to the cold water supply and was working fine but now it is not heating up the water , it is not showing any faults so not sure what is wrong
    President:
  • 1,462 Answers
Two things to check
check continuity thru heater
remove outer door panel and check for faults in wiring loom
get back to me is these are both ok
Posted on Nov 14, 2008
What is error code F6 E5 in Whirlpool Dishwasher ADP 5510 IX ??? The dishwasher keeps stopping after 2-3 min of working.I haven't touched anything since the day I bought it (2 months ago)
Fault Code F5
Dishwasher Spray arms are clogged or otherwise malfunctioning
F6 Fault code
Dishwasher doesn't detect any incoming water despite the water inlet valve being open.
Nov 10, 2016 | Whirlpool Dishwashers
Does a whirlpool ADP5000 dishwasher have an automatic heater if the dishwasher is connected to cold water outlet?
yes almost all dishwashers need to be connected to cold water as they have a heater in them, alot of newer dishwashers will bring up a fault code if you connect it to hot water
May 01, 2016 | Whirlpool Dishwashers
I have a Diplomat Fully integrated dishwasher model ADP 8242 when put on any program it fills and seems to be washing then stops after 5 minutes and the dispenser door has not opened. There is a lot of...
Check the small drain pump. Possibly its asking the pump do drain to allow for fresh water, but because low level is not detected it shuts down. The dispenser draw normall opens when the hot wash cycle starts.When you think its washing,briefly open door and see if eater is spraying out of the nozzels.If no water visible, check the main wash motor for sticking
Sep 24, 2009 | Dishwashers
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
I have a Diplomat ADP 8520 dishwasher (possibly SMEG manufacture) which will not stop trying to empty. There are 4 leds lit reading left to right and it beeps. I have read on some forums about pressing the...
fault is probably water in the bottom tray operating the anti-flood device. take bottom front panel off and mop out the water and it will work. if fault reoccurs then you have a leak
Nov 05, 2008 | Dishwashers
Diplomat Dishwasher Model ADP 8132
Please can you give me the dimentions of this Dishwasher Diplomat Model ADP 8132, as I have got to get a replacement and have been told that the Hotpoint FDL570X is the replacement offered,Many Thanks,
Mar 28, 2008 | Dishwashers
Diplomat dishwasher adp 8322
i had same problem and have found that under the lower basket the connecting bar to the spray arm had become detached this can be reattached by inserting the two nozzles back into position and pushing down youll see what i mean ! however i have found i now have to do this after every wash ,am currently onto diplomat to rectify this completely , hope this is any use.
Mar 09, 2008 | Dishwashers
Dishwashers Logo
932 people viewed this question
Top Dishwashers Experts
