Question about Jensen VM9510 Car DVD Player
BRIGHTNESS CONTROL I CAN NOT REDUCE THE BRIGHTNESS IN THE SMALL DISPLAY WHEN THE MAIN SCREEN IS INSIDE
  • Anonymous Mar 06, 2008
    the brightness on the face of the dvd player when the screen is in is too bright
  • 944 Answers
Here is the link for the manual if you need it - ask again if you don't find what you need. http://audiovox.com/manuals/owners/VM951... Hope this helps :)
Posted on Mar 10, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 11, 2007
    Sorry was a bad link should be:
    http://www.audiovox.com/
    Click on Jensen, select multimedia, then select "older models" and half way down you will find the link to the manual.
    Hope this helps more:)
SOURCE:
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Apr 17, 2016 | Princeton Digital VL173 Monitor
Tip
Notebook daily province electricity small coup
Daily use, some electricity skills, also can make using laptop for we extend, especially for IBM Thinkpad R60 Laptop Keyboard some of the endurance of large power ", "control effect is notable.
A notebook, LCD display a large screen brightness, reduce power consumption can be very effectively reduced, extend battery time, dark environment does not need higher brightness, we can reduce it. On a keyboard, most of the key combination adjustment screen brightness, "+ F6 / F7" 12.7mm Fn, specific operations can see random instructions.
Second, the lower screen brightness can effectively reduce the consumption of notebooks
Secondly, the screen saver "cancel", also can increase battery life. In his seat to use, the best friend to cancel the screen saver, set to save electricity or the standby mode, according to different operating system, set up different ways in the next section, we will be introduced in detail. The specific operation for cancellation in desktop screen saver, choose empty place use right "properties", and then select "screen saver", "no" directly determine choice.
Three, based on some common port or hardware "blocked", also can be used in mobile save considerable power. As to pull similar PC card, USB, IEEE1394 etc, or any device interface to disable the cd-rom, wireless network and bluetooth devices, can save Acer ZA3 Laptop Keyboard electricity. Disable hardware equipments, such as common as: drive, right click the "my computer", select "properties", and then select "device manager," in the menu options and find the hardware in the pop-up menu, select "disabled" or "uninstall". For wireless network and the disable bluetooth devices, is accomplished through a shortcut, please see the relevant machine operation manual.
Four, timely monitoring system resources, adjust working condition, reduce process books can also access time, notebook. Through the combination of buttons, "Del + Alt + Ctrl," v process menu, and then to process resource Settings, or operation such as "super rabbit" system, clean, tidy modify system repair operations are not only can also can save energy, space system kill two birds with one stone.
Five,HP 533549-001 Laptop Keyboard the discharge of battery correctly, can enhance battery features, so as to achieve the ideal power supply. Most of the new laptop computers using standard lithium ion battery, the battery is not so much for the full charge of the operation, but they are still weak memory effects, this in notebook computers use 1 years will become particularly obvious,
especially those in power everyday use of users. The ideal discharge operation, should be every 2 months for a full battery discharge, and take place next wipe and ventilation. It can increase the battery life and maintenance performance.
on Sep 21, 2010 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Is there any way to brighten my screen on my acer aspire 5601 lap top
Examine the keyboard. There should be a symbol on most of the function keys (F1, F2, etc.). Look for one that looks like a sun or lightbulb, either with an arrow pointing up or with the sun/lighbulb filled in. Hold the 'Fn' key, and tap the up/bright sun/lightbulb key a few times. The screen should increase in brightness.
If you cannot find the specified keys, you may be able to adjust brightness from inside Windows. Right click on the battery icon in the taskbar and open 'power options'. Look for a sun and moon with a sliding bar between them. You might also be able to adjust brightness by customizing your desktop (right click on the desktop and look for the proper menu).
Mar 22, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
I would like to reduce brightness on my ASUS VH242H
Actually, the problem isn't with the drivers. Right click on the battery icon in your system tray. Select "Power Options" (NOT Power4Gear eXtreme). On the right panel, select "Adjust the display brightness." Then, select "Change advanced power settings." Scroll down and open up the "Display" box. The options that are affecting your screen brightness on battery are "Allow SmartDimmer to reduce my brightness after," "Have SmartDimmer reduce my brightness by," and "SmartDimmer full-screen video mode." Playing with the percentages in these boxes will affect how your screen brightness adjusts itself. To get my screen to stop re-brightening itself, I changed "Allow SmartDimmer to reduce my brightness after/ On Battery:" to 100%. I then changed "Have SmartDimmer reduce my brightness by/ On battery:" to 0%. Finally, I set "SmartDimmer full-screen video mode/ On battery:" to Maximum Power Saving. This should solve your screen-rebrightening problems even with the 163.44 drivers (I use those too). Please Rate.
Thanks, Anand Fixya
Dec 23, 2010 | ASUS VW193T Monitor
How to change the 'Contrast' and 'Brightness' on the monitor screen
Bootup your computer and display your Windows Desktop. Make sure yourmonitor stays on for at least half an hour before you begin, so that itis properly warmed up.
Seta pure black image on the monitor so you can adjust the brightness. Toget a pure black image, do the following: Choose Start, then ControlPanel, then Display. This will open the Display Properties dialog box.Click the down arrow next to the representation of the desktop color inthe Color field. Choose black from the color palette, then click OK.
Maximizethe Brightness control on your monitor, then slowly reduce it until theblack of the image perfectly matches the black at the edge of thephysical screen. This puts the brightness at the proper setting.
Open a screen with a plain white background soyou can adjust the contrast. One of the best ways to do this is to open aword-processing document without any text in it. Gradually reduce the contrastsetting of your monitor until the white area of the screen begins to lookslightly gray or off-white. Then gradually increase the contrast until thewhite area on your monitor is pure white. This will give you the proper whitebalance. Now you've got your monitor ready for peak performance.
Hope this may help you solve your problem.
Nov 12, 2010 | Computers & Internet
The screen is to dark
The Problem is Most Likely you need to adjust the brightness, to do so: GameBoy Advance: you can just turn the brightness on and off from the main screen
GameBoy Advance SP: you can turn the brightness from brighter to darker (main screen again),but not off. And you turn the brightness on and off by pressing the small button near the screen.
Sep 27, 2010 | Nintendo Game Boy Advance Console
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Screen Brightness
windows 8 to 10 have the brightness control in the action center or power settings or look in the charms bar if your using windows 8 or 8.1 (note: if brightness doesnt change it maybe due to the OS not knowing how to change the brightness let me know if that ends up being the case)
Dec 17, 2017 | HP Wireless Optical Mouse
Screen turns off, i press Fn+F6 screen comes back on for a few seconds and turns off again. when i reduce brightness it stays for a longer period of time
have you tried checking to see if you have min low for sleep mode or hibernation try check in control planel in display
Feb 14, 2010 | Acer Aspire 1691WLMi PC Notebook
Jensen VM9510 Car DVD Player Logo
69 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
