Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Unable to fit new belt
Looked at manul but unable to understand how to replace belt
  • 372 Answers
Hi.
Your model has A clutch fitted so it will have 2 belts one from motor to clutch second from brush roller to clutch.
You will be told that you cant replace both belts & you can only replace the clutch to motor belt.
This is rubbish both belts can be replaced.
You will need to strip some of the machine down in order to remove the clutch & replace one or both belts.
No special tools are required except for the screwdriver which is torx T15.
Manuals on stripping the Dc07 are available from here http://dysonmanuals.llc.nu/
Posted on Jan 04, 2009
  • 107 Answers
Yes you must take it somewhere to get service or see if you can purchase a clutch assembly to replace. It is a moderate task but I am willing to help.
Posted on Dec 05, 2008
    Problem Solver:
  • 7 Answers
You cannot do this has to go to service center or local vac shop
Posted on Dec 04, 2008
I replaced the belt but as soon as I start the vacuum I smell burning and the belt is broken?
The brush roller is clogged with debris and unable to rotate. Because of this, the new belt was unable to move and the motor shaft spun in one place until it burned through. The brush roller has to be removed and disassembled to allow the end caps to be cleaned inside.
Dec 26, 2016 | Vacuums
New belt seems to be too short cant get it on
Is this the belt for the "Power Nozzle"? If so, once you have the bottom plate removed to get at the roller brush. You will be able to carefully pull/pry the roller out. It is one piece with bearing/bushings one each end. They are friction fit (held in by friction - no screws, glue or other fasteners). Remove the roller straight out, slip the belt over the roller and carefully put the roller back in. If it still won't fit, you might want to ensure you have the proper replacement belt.
see this video as an example:
Belt replacement on Rainbow e2 Black Power Nozzle
Aug 12, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Revolving brush is not turning
The belt is broken.Turn the vacuum so you are looking at the brush.That palte needs to come off.Some screw and some just pop on and off.When you have the plate off lift the brush out.The belt fits in a groove on the brush.The other end of the belt fits on a small wheel about 6 inches behind the brush.Put the new belt on and replace the plate.
May 18, 2011 | Kenmore Vacuums
The brush roller stops turning and I can smell the belt burning, then it will catch and start working normal. I looked under the plate to check the belts and they looked okay and no hang ups of string or...
better to replace both belts the smaller one is stretched out thats whyits slipping ,be sure to clean the old rubber off the motor shaft before replacing the belts.it will cause the new belts to run unevevly and go bad before their time
Aug 30, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Unable to replace belt
On most machines you have to remove the bottom plate to replace the belt. Simply remove the screws, take out the old belt, put the new one around the motor shaft, then around the brush roll and stretch into place.
Apr 15, 2009 | Vacuums
Need belt for Everstar 5990 vacuum cleaner
I just replaced the belt on my Everstar VC-9550 and it works fine. I found it at Home Depot for $3.99. The belt is sold under Vac Belts item No. 51007 (Designed to fit Bissell Uprights, Style 7,9,10).
Apr 05, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Trying to fix new belt to Hoover Turbo Power vacuum cleaner. Don't see how the belt becomes taut. Fitting it around the roller, there is nowhere to fit the belt to, it just sits loose.
I looked at the user instructions guide online and saw where the 'other end' of the belt should be fitted. It was extremely hard to fit but eventually managed it. Thanks for this solution site. I wouldn't hesitate to use it again.
Feb 17, 2009 | Hoover U5396-900 Turbo Power Vacuum
Hoover Elite Rewind belt part number , is this the correct one?
Yes, that is the correct belt. The full part number should be 38528040. This is the correct belt and should fit your U5509/U5507.
Dec 23, 2008 | Hoover Elite Rewind Bagless Upright...
Eureka Capture 8803AVZ - EXTREMELY loud
Had it checked for the noise. Motor bearings go out after a few months is what the AUTHORIZED repairman said. Toss it.
Mar 05, 2008 | Vacuums
Roller brush won't spin (bissel 6390/3910 series)
I just fixed mine. It took me all of 10 minutes. Pull the brush out. Stand the brush on end on the edge of your study work bench/table top. while holding the brush vertical( on end) take a small phillips screwdriver and tap using a hammer on the metal pin you see in the middle of the brush. Keep tamping and the whole assembly will come apart. What you will have then is a long metal shaft, 2 bearings(they are acutally skateboard wheel bearings same number same make). Clean the gobbed up hair with a razor blade and then reassemble by tapping back together. The bearing wont be worn out because they are way too tough for a vaccum. We used ride down hills on them! a ten minute fix wow and you wont have to drive to vacuum shop and spend $$ and time
Dec 31, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
234 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
