Question about GE (PSS26MSRSS) Side by Side Refrigerator
Milk freezes on refrigerator side even after lowering temperatur
How can this problem be corrected?
  • Anonymous Nov 14, 2008
    apparently thousands of people are having this same problem, why hasen't GE offered to help consumers?
    Problem Solver:
  • 18 Answers
There is a door that is controlled by the computer board that opens and closes in the fridge on the back wall near the ceiling. this door is likely broken and constantly letting cold air into fridge.
Posted on Nov 15, 2008
  • Krames
    Krames Nov 15, 2008
    i do not know, thousands out of many millions sold is very small, and with new technology comes different problems, all manufactures are using these small doors and motors for greater control of temp and efficiency
Freezing milk and water bottles on top shelve
Defective temperature sensor in the fridge section.
Aug 30, 2016 | Frigidaire Refrigerators
Refrigerator is too cold even when adjust the temperature
Too much freon? Or maybe you got the controls mixed up. My refrigerator used to freeze a gallon of milk over-night.
Nov 18, 2012 | GE Adora DSS25KSTSS Stainless Steel Side...
Milk, lettuce freezes after temperature is reduced
turn both control to the same number the lowest number and then wait 24 hrs if you want it needs to be cooler move both controls 1 number then wait 24 hrs and see if you are happy
Apr 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
WE BOUGHT A 25 CUBIC AMANA REFIGERATOR AND WOULD LIKE TO KNOW WHAT TEMPERATURE SHOULD THE REFIGERATOR BE AT. OURS WAS SET AT 4 BY THE INSTALLER, BUT I HAVE NOTICED THAT OUR MILK IS SPOILING BEFORE THE...
Depending on which is the lower temp settting I would say you are correct I would set it to a higher no.Assuming the higher no.is a colder setting and not vice versa try 5 for a day or so and test the milk by drinking it and see if it is much colder but not freezing.if npot cold enough go to 6
Mar 07, 2010 | Refrigerators
My refrigerator is freezing my food.
i think your temperature meter is not working correctly try to measure temperature of the food articles and then relate it with the 40 deg. F and measure deviation and set it at higher value accordibgly
Feb 25, 2010 | LG LSC27931S Side by Side Refrigerator
Model #PSC25MSTA SS - one year old, never got a manual with refrigerator, don't know how to lower the temperature. suddenly, ice cream melting; milk sour; push buttons to lower temperatures, does not set a...
Had a problem similar to this with this frig and the problem was a bad mother board that kept the fans from operating correctly to disperse the temperature. I woould actually get stalagtites forming from the warmer top shelves to the colder lower shelves. Repaire under extended warantee.
Jan 11, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Fridge compartment is freezing food/milk etc
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 06, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Fresh food side too warm
Refrigerator nguyen@ite.net 40 F or lower is the recommended refrigerator temperature to slow bacterial growth and maintain quality. Freezing occurs at 32 F; adjust refrigerator accordingly between 32 F and 40 F to prevent unwanted freezing, such as freezing milk.
http://lancaster.unl.edu/food/ciq-fridge-freezer-thermometer.shtml
Jun 09, 2009 | GE GSS25JFM Side by Side Refrigerator
Freeing food in refrigerator, even vegetables in vegetable tray
You have 2 dials in the refrigerator. One is the thermostat setting the cold temp in the freezer, the other is a damper that allows cold air from the freezer to the refrigerator. Set the thermostat to the middle then try closing down the damper, most say colder or warmer refrigerator. If the damper is closed and your refrigerator is still freezing, then I would guess that the thermostat is bad. A thermostat runs about 40 to 60 dollars wholesale. Retale should be about double.
Oct 20, 2008 | Samsung RS2534 Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
583 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
